proximity sensor
jsotomar
Member - Posts: 13
Posted: April 22, 2013 at 2:30 PM / IP Logged
Hi all,
I installed a Autopage RS-665 r/s to my 02 Explorer. Everything works. Now I would like to install a proximity sensor. The alarm came with a shock sensor that plugs in to the brain.
To install the proximity, do I just tap into the RED / BLACK/ GREEN/ blue wires? Do I have to cut the green wire from the shock? Do I need to have another aux port? I would like the warn & full-out modes for both sensors.
Alarm installed:
AutoPage C3 RS-665
Proximity Sensor wanted:
Omega AU-94TM
Would this be replacing both sensors or is it just a re-named proximity?
Directed 508D
Thanks!
I love Cheese.
Posted: April 22, 2013 at 2:58 PM / IP Logged
The 508d is compatible, a dual zone prox.
You will need 4 x 1N4004 diodes and the wiring is thus:-
jsotomar
Member - Posts: 13
Posted: April 22, 2013 at 3:38 PM / IP Logged
Ok, thanks! that was fast proximity sensor -- posted image. proximity sensor -- posted image.
I love Cheese.
jsotomar
Member - Posts: 13
Posted: April 23, 2013 at 8:12 AM / IP Logged
One more question. I have installed the siren that came with the alarm. Now I wish to add the factory horn with a pulse in combo with the siren. With chirps, warn, and full-out. Do I need to add a relay for this? Do I tap into the parking lights wire dioded?. As of now, I dont have the relay installed for the dome light, this wire is just grounded (White Wire - Dome Light supervision).
Just a note, prior to this alarm install, my factory OEM keyless entry does pulse the horn when a door is opened. The Autopage only uses the siren, not horn.
Thanks in advance. proximity sensor -- posted image.
I love Cheese.
Posted: April 23, 2013 at 11:00 AM / IP Logged
You need two relays.
a) Brown siren output, branch out with an inline 1N4004 diode, band towards relay, to 86.
Good grounds to 87 and 85
30 to yellow/light green or yellow/light blue, steering column loom or CSM.
White to second relay with an inline diode, 1N4004 with the band away from the relay.85
12V+ constant 5 amps fused to 86 and 87.
30 to blue/black dome supervision, driver kick panel.
jsotomar
Member - Posts: 13
Posted: April 23, 2013 at 11:03 AM / IP Logged
Ok, thanks for all the info!
I love Cheese.
Thursday, November 13, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
