2006 ford f150 pats bypass suggestions
miller88
Member - Posts: 6
Posted: July 14, 2013 at 3:57 PM / IP Logged
Ok new user, I have a 2006 Ford F150 that I am trying to install a bypass for my remote start addon. Bought a Code alarm CA4051 and got it installed in my truck and it works as advertized so there is nothing wrong with the remote start itself. My problem is that I cannot make the PKALL or the $7 DEI 555F to work to bypass the PATS on my truck. I have given up trying to make them work for the time being, but I did try to follow the instructions and make it work. I am now using a Express kit universal bypass to use the remote start by hiding a key inside a box in the truck but I would rather use a data bypass system like the PKALL so that I can start the truck without a key inside. If anyone has had experience with this particular truck and have used another product with success or if you have gotten the PKALL to work on this truck I would like to know. For the record I have 3 different keys for this truck and I have tried all 3 to program the PKALL. If any one has any suggestions I would appreciate some feedback. Thank you in advance.
pentavolvo
Copper - Posts: 241
Posted: July 14, 2013 at 4:21 PM / IP Logged
You realize you have to use two keys to program pkall correct
miller88
Member - Posts: 6
Posted: July 14, 2013 at 4:27 PM / IP Logged
Yes, I do understand that I have to use 2 keys to program the PKALL. I have 3 keys. At least one of these is a clone of the other. If all 3 are a clone of the first then I could have a problem. But I have attempted to program the PKALL with 2 keys.
pentavolvo
Copper - Posts: 241
Posted: July 14, 2013 at 6:26 PM / IP Logged
What happens when you try to program the pkall
miller88
Member - Posts: 6
Posted: July 14, 2013 at 6:30 PM / IP Logged
As far as I can tell, the LED on the PKALL remains solid. I put in the first key, turn to On, wait 5 sec. Remove 1st key, turn second key to on, wait 5 sec, remove second key. Activate remote start, PATS light flashes to prevent engine starting. Not sure if I am doing something wrong or there is another procedure.
Platinum - Posts: 7,827
Posted: July 14, 2013 at 7:44 PM / IP Logged
PKALL's can be touchy to program. I remember doing a 2007 F150 a while ago, Used a Directed 1100F which is basically the same as an ADS TB with the ADS TB FM2 firmware. Worked great ( they always do ).
Anyway, sometimes the install guides have the RX and TX wire locations mixed up. For your truck, it's a 4 pin connector at the ignition switch. TX is at Pin 3 and is WHITE/ Light Green and RX is at Pin 4 and is Gray/Orange.
You obviously have the correct Viper (-) Status Output going to the PKALL's Blue/White GWR wire.
Other than that, you must have two, unique, working transponder keys to add the bypass module. Timing is very important, too.
miller88
Member - Posts: 6
Posted: July 14, 2013 at 7:53 PM / IP Logged
Looks like I got the wiring connections correct. No kidding that they are touchy to program. Would it be better to just cut the thing out and go with a 1100F?
Posted: July 14, 2013 at 8:05 PM / IP Logged
I prefer them on all 40 bit Fords. Easy to setup and program, very reliable and the sub $20 price can't be beat. Another big selling point it that a Factory Reset will allow you multiple programming attempts and even use on another vehicle if you upgrade to another 40 bit Ford.
Are any of your three working keys original Ford keys? Also, it's a good idea to make solder connections on these transponder wires.
miller88
Member - Posts: 6
Posted: July 14, 2013 at 8:08 PM / IP Logged
All 3 are OEM Ford Keys. Not really sure which one is the original but the dealer made copies for sure. Now that I have looked at it looks like that is what I am going to do, since my next truck will likely be a Ford truck. I will let you guys know how it works.
Posted: July 14, 2013 at 8:19 PM / IP Logged
Yes, please keep us posted.
While the 1100F install guide stops around 2006, I've used them on many newer Ford vehicles ( 2010 F150's and even a 2012 Fusion / MKZ ). You can use the ADS TB install guide as a reference on newer Fords ( non 80 bit systems ).
Saturday, September 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
