camry 2014 remote start wiring?
pesho
Member - Posts: 12
Posted: November 21, 2016 at 1:24 PM / IP Logged Link to Post Post Reply Quote pesho
I need help with wiring a remote start with toyota camry 2014 standart key.
I need help with the ignition connector.
the camry conector have wires as follow:
Pin6 Ignition1 Black    thick wire
Pin1 Ignition2 Pink     thin wire
Pin3 Starter1 Lt.Green thin wire
Pin7 Starter2 Blue     thick wire
Pin5 +12V Batt Green    thick wire
Pin2 Accessory White    thin wire
the remote starter have:
ACC
IGN1
BAT
BAT
START
IGN2
how they should be connected?
Thank you in advance!
Posted: November 21, 2016 at 2:19 PM / IP Logged Link to Post Post Reply Quote howie ll
Are you kidding?
Ah well here goes:-
Both your batts to pin 5 or to thick white feeding dash fusebox or management ECU
ACC to pin 2
Ign 1 to pin6
Ign 2 to pin 1
Start to pin 7
As for your second starter, what brand of R/Start are you installing?
pesho
Member - Posts: 12
Posted: November 21, 2016 at 4:46 PM / IP Logged Link to Post Post Reply Quote pesho
No i Don't kidding!
the remote start Audiovox APS57A there is install manual online for APS57A which is the same.
it is obvious that the accessory go to accessory and so on, but I don't know about the second starter wire!?
the car won't start! when the remote starter try to start the engine it turns on the ignition ( the dashboard light up and you can hear the gas pump running), but the starter don't engage/crank the engine.
I don't know where and how to huck up the second starter wire.
Posted: November 21, 2016 at 4:54 PM / IP Logged Link to Post Post Reply Quote howie ll
Isn't there a secondary NEG starter output (thin) on the loom?
Posted: November 21, 2016 at 5:02 PM / IP Logged Link to Post Post Reply Quote howie ll
This is for the APS57E but it should be the same:-
14 pin plug, pin 8 BLACK / YELLOW use a standard automotive relay with a diode 1N4004.
BLACK / YELLOW to 85
Wire from IGN 1 to 86
30amp fused constant to 87
Wire to second starter from 30
Diode goes from 85 to 86, band towards 86.
pesho
Member - Posts: 12
Posted: November 21, 2016 at 5:17 PM / IP Logged Link to Post Post Reply Quote pesho
all wires that are available are in my first post. please look at it.
I'm not familiar with the new cars. I'm duing this for friend of mine and I don't do this for living, this is my third install of remote starter.
I don't know if second starter is necessary at all. Can you explain the sequence how the whole thing works, maybe I can put a diode/s to the starter wire/s and connect them together???
pesho
Member - Posts: 12
Posted: November 21, 2016 at 5:28 PM / IP Logged Link to Post Post Reply Quote pesho
ok I see... the ignition1 and ignition2 should have positive at the same time during start/crank. is that correct?
Thank you for the help! I don't have the car right now, but during the weekend we can will try.
pesho
Member - Posts: 12
Posted: November 21, 2016 at 5:33 PM / IP Logged Link to Post Post Reply Quote pesho
I mean igniton1, igniton2, starter1 and starter2 should have positive during start/crank ???
Posted: November 21, 2016 at 5:36 PM / IP Logged Link to Post Post Reply Quote howie ll
With Toyotas yes. Most other cars IGN isn't that needed to start normally runs HVAC, windows, wipers etc.
pesho
Member - Posts: 12
Posted: November 21, 2016 at 5:48 PM / IP Logged Link to Post Post Reply Quote pesho
OK Thank you!!!
Friday, December 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
