2015 Hyundai Sonata, Security and Remote Start
dhall764
Member - Posts: 14
Posted: March 08, 2020 at 5:11 AM / IP Logged Link to Post Post Reply Quote dhall764
I have 2015 Hyundai sonata, I purchase a astra a777 car alarm with startlink both by scytek. I also have idatalink alca bypass module. I've flashed module,pts module programing done my car wont remote start any solutions for issues.?
5909 plumer ave.
djdeito
Copper - Posts: 100
Posted: March 08, 2020 at 9:24 PM / IP Logged Link to Post Post Reply Quote djdeito
does your Sonata cranks the engine when you attempt to remote start it?
did you make all the required connections from the iDatalink Alca bypass to your vehicle?
and for clarification, is your 2015 Sonata Push-to-Start?
dhall764
Member - Posts: 14
Posted: March 09, 2020 at 6:16 PM / IP Logged Link to Post Post Reply Quote dhall764
yes it does cranks once then stops also it is push to start,i have two diodes in line with the two connecting two wires.i was told the data wire is not connected on the wrong side(gray and red wire).
5909 plumer ave.
djdeito
Copper - Posts: 100
Posted: March 09, 2020 at 6:31 PM / IP Logged Link to Post Post Reply Quote djdeito
is the iDatalink Alca bypass installed in the A777 module using data-to-data cable or hardwired?
if data-to-data:
did you make sure option 21 "databus interface mode" is set to "iDatalink" on the A777 module?
did you set the iDatalink Alca bypass to data mode?
did you install the DBi firmware in the iDatalink Alca bypass?
dhall764
Member - Posts: 14
Posted: March 09, 2020 at 9:11 PM / IP Logged Link to Post Post Reply Quote dhall764
i install ads on the module, the data wire was used and set to data mode, not sure what option 21 is
5909 plumer ave.
dhall764
Member - Posts: 14
Posted: March 09, 2020 at 9:24 PM / IP Logged Link to Post Post Reply Quote dhall764
did i flash the wrong firmware?
5909 plumer ave.
djdeito
Copper - Posts: 100
Posted: March 09, 2020 at 9:49 PM / IP Logged Link to Post Post Reply Quote djdeito
flash the DBi firmware to the iDatalink Alca bypass and then try to remote start your vehicle.
dhall764
Member - Posts: 14
Posted: March 09, 2020 at 10:16 PM / IP Logged Link to Post Post Reply Quote dhall764
I'm willing try that,we'll see what I get tomorrow afternoon
5909 plumer ave.
djdeito
Copper - Posts: 100
Posted: March 11, 2020 at 12:55 PM / IP Logged Link to Post Post Reply Quote djdeito
Does your installation for the Astra A777 and iDatalink Alca look like this:
2015 Hyundai Sonata, Security and Remote Start -- posted image.
dhall764
Member - Posts: 14
Posted: March 13, 2020 at 3:36 PM / IP Logged Link to Post Post Reply Quote dhall764
Yes it does,my problem is trying to figure out what to flash on my idatalink alca I've already flashed it 2 way. It would crank once but not start, would that be possibly be a tach wire.?
5909 plumer ave.
Page of 3
Sunday, July 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
