Viper 3105V, Bypassing Control Center Antenna LED?
joseph58
Member - Posts: 8
Posted: August 12, 2021 at 1:20 PM / IP Logged Link to Post Post Reply Quote joseph58
Hello,
I want to bypass/disable the 'all-in-one module' LED, wiring a separate LED directly to the dash.
- Viper alarm LED (red + blue)
- Antenna/valet switch/LED all-in-one module (gray+blue+black+red+green+pink)
Could not find any intermittent current on any of the 6 wires when alarm was activated.
Red wire on the all-in-one module has constant 5v.
Any help would be appreciated!
Viper 350 Plus (Model 3105V)
t&t tech
Platinum - Posts: 2,622
Posted: August 23, 2021 at 8:22 PM / IP Logged Link to Post Post Reply Quote t&t tech
Just go directly to the control module. Unplug the led plug from the port and you can plug an in dash led directly to the module, P.S you can get an original viper led from any alarm shop in your area, they come in red and blue.
Friday, January 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
