keyless locks
scelsi14
Member - Posts: 26
Posted: June 21, 2003 at 12:04 PM / IP Logged
I have my keyless locks installed and everything, but it will only lock with the remote. I found that if i put the "lock" wire coming out of the actuator on a ground, it will unlock. By doing this I have to remove the wire from the harness coming out of the sensor module. Does anyone know how I would wire relays to accomplish this without having to manualy ground the wire to unlock this?
chuck_tempe
Copper - Posts: 58
Posted: June 21, 2003 at 4:44 PM / IP Logged
i don't know what kind of vehicle or alarm you have, but what you can is install a relay for the unlock.   the pulse for the unlock would trip the relay to provide a ground to your "lock" wire.  i need some more info to provide you with more details.
scelsi14
Member - Posts: 26
Posted: June 22, 2003 at 2:44 PM / IP Logged
I figured I needed a relay but I can't figure out how to wire it to do that. I tried to do it myself, but it didn't work right. How would I run the wires to accomplish what you're saying?
Moderator - Posts: 12,488
Posted: June 22, 2003 at 5:30 PM / IP Logged
Use this diagram for aftermarket actuators
scelsi14
Member - Posts: 26
Posted: June 22, 2003 at 7:43 PM / IP Logged
I tried that relay setup and it won't lock or unlock.
Posted: June 22, 2003 at 8:00 PM / IP Logged
Does each lock and unlock wire coming from the keyless module output a (-) signal when you lock and unlock with the remote control ?
chuck_tempe
Copper - Posts: 58
Posted: June 22, 2003 at 11:39 PM / IP Logged
scelsi14, can you provide us with more details about the vehicle or alarm make/model that you are using?  we need to know if you are using aftermarket actuators or if your vehicle is equipped with factory doorlocks.
scelsi14
Member - Posts: 26
Posted: June 23, 2003 at 8:56 AM / IP Logged
Oh, sorry, I forgot to mention that. I have an aftermarket keyless lock set. My car is a 91 Pontiac Sunbird.    Here's a link to link where I got the lock set. Thanks for any help.
scelsi14
Member - Posts: 26
Posted: June 23, 2003 at 9:01 AM / IP Logged
Velocity Motors, what equipment would I need to see if it is a (-) signal? I have a multimeter, but it appears that will not show me such a signal.
Posted: June 23, 2003 at 9:20 AM / IP Logged
You need to set your DMM to DC and place the RED lead to a constant 12 volt source and the BLACK lead to the target wire. Now press the lock or unlock button on the remote control and the corresponding wire will make the DMM jump up to 12 volts momentarily and back down to 0. Both wires should do this when you press the lock/unlock button.
Thursday, December 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
