04 honda accord
godsegoizhuge
Copper - Posts: 214
Posted: February 09, 2004 at 5:25 PM / IP Logged
Got an 04 accord coming in tomorrow, so can anyone send me the wire info for this car?   Also does this car use the 555H or the 555U bypass module?   Also is there anything surprising i should watch for when i'm installing this system?
godsegoizhuge
Copper - Posts: 214
Posted: February 09, 2004 at 5:43 PM / IP Logged
forgot one other thing.....anyone know how to program a 3rd key?   is it like the fords or does the honda dealer have to go in with a special computer to program it?
securinu
Silver - Posts: 772
Posted: February 09, 2004 at 8:51 PM / IP Logged
Honda will have to code it . And they have the remote built in to the head of the key.
Joe O'Byrne
Owner / Installer
JWorm
Platinum - Posts: 2,208
Posted: February 09, 2004 at 9:18 PM / IP Logged
The 555H will not work. I have heard the 555i might work, but I'm not sure. I use the PKH3 from bypasskit.com on the 03+ Accords. The car comes with 3 keys. Two of them have the remote control built in, the other key is the valet key without the remote built in. Make sure the customer brings that key in if they are going to sacrifice one. Additional keys must be coded at dealer.
If the car has the factory alarm (EX models only I think) you will need to run two wires into the door (one for arm, one for disarm). Colors are white and WHITE/ red at window switch. There is a molex plug in the door with a ton of grease on it.. If you undo the plug you can run two wires thru existing unused holes in the plug. I use 22 gauge wire because the holes are really small. They can probably be drilled out if you have to use larger wire.
Saturday, February 21, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
