2000 Prelude factory alarm connector
patgill
Member - Posts: 6
Posted: November 23, 2004 at 10:37 PM / IP Logged
Hi,  im installing a viper 791 in my prelude and im having trouble finding some of the wires.  I have the diagram from this site and it says the door trigger is BLACK/ white at the factory alarm connector. I can't find this connector.  I found a WHITE/ black wire at the bottom of the fuse box that is connected to the door trigger but im not sure if this is it.  could someone give me a more detailed location of this harness.  thanks
ninjazx6e
Member - Posts: 11
Posted: November 23, 2004 at 10:50 PM / IP Logged
that is the correct wire
patgill
Member - Posts: 6
Posted: November 23, 2004 at 11:08 PM / IP Logged
The only reason why i don't think thats it is because there should also be a RED / white and a GREEN/ orange and there isn't.  are you sure thats the location of the factory alarm connector??
patgill
Member - Posts: 6
Posted: November 23, 2004 at 11:35 PM / IP Logged
anybody else???
Platinum - Posts: 12,488
Posted: November 24, 2004 at 6:35 AM / IP Logged
The alarm connector is GREEN with about 20 + wires in it. It will be hgh on the driver's side dash.
patgill
Member - Posts: 6
Posted: November 24, 2004 at 10:43 AM / IP Logged
do i need to pull the fuse panel off.  ive looked so hard and still cannot find it.
patgill
Member - Posts: 6
Posted: November 24, 2004 at 11:15 AM / IP Logged
also if i don't have a factory alarm where can i find the door trigger, and door lock/unlock
Posted: November 24, 2004 at 11:39 AM / IP Logged
The alarm plug will most likely be taped up against another loom of wires high under the driver's dash area. There will most likely be blue tape holding it up there. Even if the Prelude didn't come with OEM security, the plug will still be there for you to access the power door lock wires.
profuse007
Gold - Posts: 2,015
Posted: November 24, 2004 at 12:16 PM / IP Logged
|     DOOR TRIGGER|WHITE/ black        |- |bottom of fuse box          |
i used this wire, easy to find.
Houston,TX
patgill
Member - Posts: 6
Posted: November 24, 2004 at 5:07 PM / IP Logged
i took the bolts off the fuse box so i could pull it out and look around a little bit better but i still didn't find it.  im gonna look again tommorow and if i don't find it im just gonna use the WHITE/ black wire for the door trigger and find the wires on the passenger side kick panel for the lock/unlock.  thanks for your help
