Remote start range issues
tuckie
Member - Posts: 14
Posted: December 19, 2004 at 10:04 PM / IP Logged
I recently purchased a 2002 grand am used which came with remote start. The unit is a DEI valet (551 i think). Recently the range has varied anywhere from 15 feet, to 3 inches from the antenna. I have replaced the remote's battery twice to no avail. A few weeks ago i was able to start the car from the second floor of my house, now I have go outside for the remote to work. All the connections on the remote start box in the car appear fine and i have unplugged and replugged all connections in.
Does anyone have any ideas as to what may be causing this?
auex
Platinum - Posts: 5,041
Posted: December 19, 2004 at 10:34 PM / IP Logged
Kind of an oddball but, I have seen solder joints go bad on the reciever section of the board (primarily where the ant meets the board). It is worth a shot if you have a solderin iron.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Platinum - Posts: 12,488
Posted: December 19, 2004 at 10:48 PM / IP Logged
Get a new antenna..... this can solve alot of range issues.
tuckie
Member - Posts: 14
Posted: December 19, 2004 at 11:03 PM / IP Logged
links?
Ravendarat
Platinum - Posts: 2,806
Posted: December 19, 2004 at 11:17 PM / IP Logged
I really dont see what golf has to do with this situation, but Augusta is amazing. If I was you I would simply go to a dei dealer and order a new antenna because that is most likely your culprit, infact I had the exact same thing happen with a customer today. Two weeks ago he got great range but today I literally had to have the remote 6 inches from the antenna to get it to work
