2003 Voyager alarm, power windows and locks
Home /
the12volt's Install Bay /
Car Security and Convenience / 2003 Voyager alarm, power windows and locks (
Topic Closed)
Welcome Guest :)
Posted: February 16, 2005 at 9:16 AM / IP Logged
Hi All,
I've came across this great site while looking for resources to help help me install an alarm, power windows and locks in a basic 2003 Voyager. I found by this topic for a 2002 Voyager and wonder if it is the same for the 2003.
2002 Voyager
Also, when installing a the power windows and locks... Where would be the best source for +12v power for these accessories on this van. Btw, I'm using OEM window regulators with SPAL pod style switches and Autoloc 4-door lock kit.
While I am confident with my ability in installing these items. I probably leave the alarm and the remote start to a professional and do the power windows and docks myself.
Thanks,
Jd999
Posted: February 16, 2005 at 9:39 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - CHRYSLER / VOYAGER / 2003 / Accessory
12volts lt. blue/red (10A) + ignition harness
Notes: This wire is rated at 10 amps only. If installing any system with high current outputs, go to the battery for 12v.
Ignition pink/white + ignition harness
Parking Lights+ DO NOT USE
Parking Lights- WHITE/ brown - headlight switch
Notes: The parking lights are negative trigger thru a 2.1K ohm resistor. There is a rest resistance on the wire, so MUST use a relay to isolate away from the switch. See directfax document #1082 for wiring information.
Headlight WHITE/ brown - headlight switch
Notes: the headlights are negative trigger thru a 790 ohm resistor. There is a rest resistance on the wire, so MUST use a relay to isolate away from the switch. See directfax document #1082 for wiring information.
Trunk/Hatch Release PURPLE / tan - conn. 2, pin 6 @ BCM
Notes: Hatch release is negative trigger thru a 1.69K ohm resistor. MUST use a relay.
The BCM (Body Control Module) is in the driver kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs.
Power Sliding Door PURPLE / blue - conn. 3, pin 1 @ BCM
Notes: Left power sliding door is negative trigger thru a 1.5K ohm resistor. Right power sliding door is negative trigger thru a 2.7K ohm resistor. MUST use relays.
Speed Sense blue/orange PCM
Notes: The PCM (Powertrain Control Module) is behind the driver side headlight. VSS is in the gray plug, pin 66.
Wipers brn/wht & brn/org + windshield wiper motor
LF Window up/dn org/lt. green - org/white A driver window switch
RF Window up/dn org/tan - org/gray A driver kick panel
LR Window up/dn org/blue - org/lt. blue A driver kick panel
RR Window up/dn org/gray - org/green A driver kick panel
Sun Roof open/close
Sun Roof Limit/close
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: Yes Type: Sentry Key Part #: 555C, 556U, or 555U
Notes: Only vehicles with gray keys have the immobilizer.
DIRECTWIRE™ WIRING INFORMATION - CHRYSLER / VOYAGER / 2003 / Remote Start
[PRINT THIS PAGE]
Starter yellow + ignition harness
Second Starter PURPLE / brown - ignition harness
Notes: The second starter wire is negative trigger thru a 180 ohm resistor. MUST use a relay. Refer to directfax document #1083 for wiring information.
Second Ignition N/A
Third Ignition N/A
Accessory not required for remote start
Second Accessory N/A
Keysense
Power Lock PURPLE / green - conn. 3, pin 21 @ BCM
Notes: Lock is negative trigger thru a 5.3K ohm resistor. Unlock is negative trigger thru a 2.0K ohm resistor. MUST use relays.
Can also use Directed 457C or 456L interface modules.
Power Unlock same wire as power lock
Lock Motor tan/white conn. 2, pin 10 @ BCM
Notes: The BCM (Body Control Module) is in the driver kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs.
Unlock Motor tan/lt. green conn. 2, pin 28 @ BCM
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger - conn. 3 @ BCM
Notes: The driver door trigger is purple in pin 6, the passenger door is PURPLE / white in pin 7, the left sliding door is PURPLE / gray in pin 8, and the right sliding door is purple / YELLOW in pin 5. Use all four and diode isolate each. See directfax document #1076 for wiring information.
Dome Supervision use door trigger
Trunk/Hatch Pin PURPLE / orange - conn. 3, pin 29 @ BCM
Notes: A diode must be placed inline on this wire to avoid problems with the dome lights and parking lights.
Hood Pin PURPLE / lt. blue - conn. 3, pin 30 @ BCM
Factory Alarm Arm PURPLE / lt. blue - conn. 3, pin 14 @ BCM
Notes: Arm is negative trigger thru a 1.5K ohm resistor, this will also lock the doors. Disarm is negative trigger thru a 9.1K ohm resistor, if use double pulse this will also unlock the doors. MUST use relays.
Factory Alarm Disarm same wire as alarm arm
Disarm No Unlock
Tachometer ac ignition coil pack
Notes: On the 2.4L use blue/green or blue/tan. On the 3.3L/3.8L use blue/green, blue/tan or blue/orange.
Wait to start N/A
Brake Wire WHITE/ tan + brake pedal switch
Parking Brake
Horn Trigger GREEN/ purple - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
DIRECTWIRE™ WIRING INFORMATION - CHRYSLER / VOYAGER / 2003 / Security
[PRINT THIS PAGE]
Disarm Defeat tan/brown conn. 2, pin 26 @ BCM
Hazards
Turn Signal(L)
Turn Signal(R)
Disarm No Unlock
Memory Seat 1
Memory Seat 2
Memory Seat 3
Be careful whose advice you buy, but be patient with those who supply it.
Thursday, December 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
