96 neon, Hiteeh HT - 455
rancidpunk
Member - Posts: 6
Posted: April 13, 2005 at 7:03 PM / IP Logged
Hey,
I am installing an alarm system on my 96 neon, and im curious about a few things.
1. I have no power locks on my car, what to do with alarm wires?
2. Ths Relates to the first one, The Unlock/Lock wires and the - and + door switch, where do they go with no power locks and whats the difference. And to do with power unlock wire if i dont have one.
3. Finally theres 2 things, on is this site does not have the hazard lights description and my install guide has two white wires for it and does no say weither on is + or -  , ok and theres also a wire for Engine Cap, ?What the hell is that, the oil cap?
Someone please help it would be nice
swamprat323
Gold - Posts: 1,335
Posted: April 13, 2005 at 8:11 PM / IP Logged
1. dotn do anythign with them. put power locks in sometime so u use them.
2. door "switch" connect to the door, only 1 of them not both, in your case it be the negtive one. cut the postive one out.
3. depending on alarm one of the parking lights will go to postive or negtive and the other to the parkign light in the, soem alarms have to parkign lights wires right and left. what make and modle of alarm do u have.
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|red & pink/black    |+ |ignition harness *1        |
|          STARTER|yellow              |+ |ignition harness *1        |
|        IGNITION|dk. blue            |+ |ignition harness *1        |
|        ACCESSORY|BLACK/ orange        |+ |ignition harness *1        |
|       POWER LOCK|ORANGE / purple       |5wi|taped harness from driv door|
|     POWER UNLOCK|pink/purple        |5wi|taped harness from driv door|
|       LOCK MOTOR|ORANGE / black        |   |drivers kick               |
|     UNLOCK MOTOR|pnk/wht or pnk/blk |   |drivers kick               |
|    DISARM DEFEAT|pink/black          |   |passenger kick              |
| PARKING LIGHTS +|BLACK / YELLOW        |   |at headlight switch        |
| PARKING LIGHTS -|                    |   |                            |
|       HEADLIGHTS|lt. green           |+ |at headlight switch        |
|     DOOR TRIGGER|yellow/black        |- |behind headlight swtch      |
| TRUNK/HATCH PIN|gray/black          |- |at light in trunk           |
|       TACHOMETER|tan/blu or blk/gry |   |top motor 3 pin plug        |
|       BRAKE WIRE|WHITE/ gold dots     |+ |at brake switch             |
|     HORN TRIGGER|BLACK/ red           |- |steering column             |
|           WIPERS|grn/yel, RED / yel    |+ |steering column *2          |
| LF WINDOW UP/DN|                    |   |                            |
| RF WINDOW UP/DN|                    |   |                            |
| LR WINDOW UP/DN|                    |   |                            |
| RR WINDOW UP/DN|                    |   |                            |
Notes:
*1 SRS airbag wires are not enclosed in sheath at the steering column. They are a twisted pair run with rest of ignition harness. Be careful not to cut or probe these wires. *2 Combine with diodes to get all speeds.
rancidpunk
Member - Posts: 6
Posted: April 13, 2005 at 9:06 PM / IP Logged
yah um my alarm is an "HiteCH Mobile Security HT - 455"
um i dont have power locks and my alarm has the wires for it, so do i just ignore them. but still install the one door switch with or without power locks, right?
also about the engine cap? theres a wire labelled for it and i dont know what it means, where its for, or if i even need it.
thanks for the help so far. please help more though if possible
rancidpunk
Member - Posts: 6
Posted: April 14, 2005 at 12:32 PM / IP Logged
hi
ive understood most everything on my alarm install except for the relay system, i have made a diagram of it. i understand were the acc wire and the orange wires go, the 12v does it go to the battery or DC and where would i find dc in my car, yellow ignition coil i get, the only other thing is the switch connecting to the 12v and the acc and how i do this. please help thanks
rancidpunk
Member - Posts: 6
Posted: April 14, 2005 at 12:37 PM / IP Logged
sorry pic didnt work first time let me try again
96 neon, Hiteeh HT - 455 -- posted image.
mo12v
Posted: April 14, 2005 at 5:27 PM / IP Logged
Is this for Ignition Kill or Remote Start??
MO
dare_ds69
Silver - Posts: 419
Posted: April 14, 2005 at 5:31 PM / IP Logged
what are you trying to do? what car is it?
how own your mind, control your life.
MECP certified. always use a DMM
rancidpunk
Member - Posts: 6
Posted: April 14, 2005 at 6:42 PM / IP Logged
its for a dodge neon 1996 and im trying to set up the relay for the ignition for an alarm. the alarm is a HiTecH ht - 455. i just want to understand what the switch is and how to wire the damn thing
mo12v
Posted: April 14, 2005 at 7:07 PM / IP Logged
If this is for Ignition Inhibit or "Kill"
Ignition Kill will not work on ALL vehicles.  U could send the wrong signal to computer and mess things up.
Starter Kill ( or Interrupt ) would be better.
SPDT Relay
1 or 2 amp Diode across PIN 86 & PIN 85 with stripe facing PIN 86
Cut Starter wire in half:
PIN 86 & 30  = Ignition switch half of cut wire
PIN 87a  = Starter side of cut wire
PIN 85 = Negative Output from Alarm while Armed
MO
swamprat323
Gold - Posts: 1,335
Posted: April 15, 2005 at 8:09 AM / IP Logged
yes ignore the power lock wires.
yes install the one door switch, this will set off the alarm if door is open while the armed.
I dont know what the engine cap is and never heard of it. Dose it say were it connect too, or dose it have "any" other info. is ther a website form were you bought it, maybe they have the manurl up so i can see it.
Just skip that wire also, as long as the door, hood, and trunk is protected you should be fine. just tape the end of the wires your not useing so they cant touch anything by mistake.
