Window Roll up / down questions
TJ92Civic
Copper - Posts: 161
Posted: August 01, 2005 at 12:12 AM / IP Logged
Hi,
I want to install window roll up / down in my car (1996 Volvo 850).  I have a Compustar 2W900FM-AS, and I want it to roll up the windows when I push the first aux button, and roll down when I push the other aux button.  It is a 4 door, what modules would be best to use to do this?  and how many will I need?  And any other info would be great!
thanks
tim
xtremeaudio
Copper - Posts: 174
Posted: August 01, 2005 at 3:28 AM / IP Logged
dei 530t is good you can use roll up and down for 2 window or 4 window roll or down
TJ92Civic
Copper - Posts: 161
Posted: August 01, 2005 at 10:07 AM / IP Logged
So I should get two of them?  One for the front windowns and one for the back.  And I can wire it to the aux outputs on the alarm?
tim
Platinum - Posts: 12,488
Posted: August 01, 2005 at 11:41 AM / IP Logged
Get two of these or get one module to do all 4 up & down. They're epensive, but worth the hassle in the installation portion. You will need to program the AUX channels for continuous or if you want to have the ability to vent the windows you can have the channels programmed for latched.
TJ92Civic
Copper - Posts: 161
Posted: August 01, 2005 at 12:01 PM / IP Logged
Thanks.  Do you know of a module that does 4 windows up and down?  And When I set it to latch, I can program the time from 1-99 sec, but it doesn't say how to program the time.
tim
Posted: August 01, 2005 at 12:08 PM / IP Logged
I'm not at the shop right now for my pricing book but I'll look one up for you . As far as the programming you have to time how long it take for the windows to go up and add about 2 seconds to that to ensure that all windows will be up. The internal voltage sensing will automatically cut out the power to the modules anyways, but having the latch output too long is better than not long enough.
minitruckin_jay
Member - Posts: 9
Posted: August 02, 2005 at 11:43 PM / IP Logged
i know i have seen autoloc makes one, or just start puttin relays on, did it on my buddys 1991 integra, 3 years later still works
TJ92Civic
Copper - Posts: 161
Posted: August 03, 2005 at 10:39 PM / IP Logged
Have you found the module yet?
thanks
tim
