door lock/unlock wont work with 350hv
littlepapa87
Posted: August 03, 2005 at 9:20 PM / IP Logged
I am installing a Viper 350HV system in my 92 Ford explorer.  I have pre-existing power door locks, but not keyless entry.  Everything was going well in the installation untill i got to the keyless entry.  I can not tell how to wire the keyless entry from the provided instructions.  the power lock switch has a pink/green wire that give off +12v when I press unlock and pink / YELLOW give off +12v when i press lock.  There is one wire that gives off constant +12v and 2 grounds.  I have tried tapping into the pink wires but it does not work.  any help on how to install this would be greatly appreciated.
swamprat323
Gold - Posts: 1,335
Posted: August 03, 2005 at 9:26 PM / IP Logged
your ahve 5 wire locks.
click here
littlepapa87
Posted: August 03, 2005 at 9:31 PM / IP Logged
i saw that earlier but i dont understand how and where to put the alarm output wires
swamprat323
Gold - Posts: 1,335
Posted: August 03, 2005 at 9:39 PM / IP Logged
the green and blue wire form alarm will go to pins 85 and 86. look at those it say - from alarm lock out put an d- form alarms unlock out put.
mo12v
Posted: August 03, 2005 at 9:46 PM / IP Logged
If your Explorer came WITHOUT Factory Keyless Entry:
U will need 2 SPDT Relays
Cut your PINK / YELLOW & PINK/Green wires in half
Relay 1
LOCK:
PIN 87 = PINK / YELLOW wire from Door Lock Actuator
PIN 87a = PINK / YELLOW wire from Door Lock Switch
PIN 30 = 12 Volts ( + ) Constant
PIN 85 = Negative Lock Output from Viper
PIN 86 = Constant 12 volt ( + )
Relay 2
UNLOCK:
PIN 87 = PINK/Green wire from Door Lock Actuator
PIN 87a = PINK/Green wire from Door Lock Switch
PIN 85 = Negative UNLock Output from Viper
If your Explorer came WITH Factory Keyless Entry:
Hook your Viper Lock / Unlock wires directly to the Factory wires ( don't cut them in half )
MO
littlepapa87
Posted: August 03, 2005 at 9:53 PM / IP Logged
do you know where pins 85 and 86 are located on a 92 ford explorer
mo12v
Posted: August 03, 2005 at 9:56 PM / IP Logged
WHOA.....................
The PINS that we are talking about will be on the 2 S P D T Relays that you need to install (Single Pole Double Throw)
MO
mo12v
Posted: August 03, 2005 at 9:58 PM / IP Logged
If you are NOT familiar with this type installation, get help from someone who knows........ You CAN cause damage to your Door Lock Switches
MO
littlepapa87
ok i thought they were in the door panel that clears a lot up for me i believe i can get it from here thank you very much for all your help
