Viper 791 Problem
Geoff897
Posted: August 14, 2005 at 5:59 AM / IP Logged
Hi all i just got my alarm installed the other day it was working fine
i pulled the stereo out and now i have the led on constantly
when i lock the car the doors lock but the windows dont go up.
when i start the car the light goes out and none of the sensors work
Any ideas on the problem??
Thank you
Geoff
swamprat323
Gold - Posts: 1,335
Posted: August 14, 2005 at 9:38 AM / IP Logged
sounds like in valet mode. form remote: open a door, hit lock then unlock and lock again. the led will go out.
Geoff897
Posted: August 14, 2005 at 3:56 PM / IP Logged
Thanks ill give that a go
Also 1 of my back windows doesnt close all the way up i needed to lock and unlock the car to get it to close all the way up any ideas.
Its in a Subaru liberty 01
Geoff897
Posted: August 17, 2005 at 6:31 AM / IP Logged
Hi thanks swamprat323 thats what the poblem was
topspoiler
Member - Posts: 29
Posted: August 22, 2005 at 4:05 AM / IP Logged
I think you have to change the resistant on the window module.
topspoiler
Member - Posts: 29
Posted: August 22, 2005 at 4:06 AM / IP Logged
tillithz
Member - Posts: 48
Posted: August 22, 2005 at 11:24 AM / IP Logged
well if its just ONE window on the two window module i would think that instead of the resistance being raised you should figure out what is dragging that one window. such as maybe an accident or moisture, or something physical inside the door causing the window not to roll up properly
