need to reprogram 556L
Moosetooth
Member - Posts: 10
Posted: October 25, 2005 at 10:41 PM / IP Logged
I had my Boa 265b working ...(except for the parking lights). In trying to fix the parking lights I erased the programming for the passlock 2 module (556L). Unplugged all the fuses and tried to re-program the module but doesn't seem to want to re-learn.  I know all the wiring is right, as I said it worked until I goofed it up. 99 S10 Blazer. The wiring data from the manufacturer listed 2 parking light wires, one + and one-. I had the parking lead from the remote starter wired to the negative one. The instructions were vague but it said a negative trigger were what was wanted. BTW my online support seems to have expired so any help I get here will be much appreciated. Thanks in advance.
mo12v
Posted: October 25, 2005 at 11:04 PM / IP Logged
TRy:
http://www.directechs.com/guides/manuals/ig/accessories/N556L_05-05.pdf
MO
extreme1
Silver - Posts: 1,070
Posted: October 25, 2005 at 11:22 PM / IP Logged
key on off on off start the truck, LED on 556L will blink 2 times, then after 5-10 seconds it blink again, you are done.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Moosetooth
Member - Posts: 10
Posted: October 26, 2005 at 1:52 AM / IP Logged
Well, I unplugged the 12v to module (I think that erases the memory, right?), key on, key off key on, start..... nothing happens. BTW, the security light stays on after I start it with the key. I guess that confirms that the 556L isn't doing everything it should. Seems to run OK starting it with the key though.
Moosetooth
Member - Posts: 10
Posted: October 26, 2005 at 1:54 AM / IP Logged
Just read my post. Key on and OFF twice, THEN start is what I meant to write.
Moosetooth
Member - Posts: 10
Posted: October 26, 2005 at 3:56 AM / IP Logged
OK, looking at my situation again, since it starts and runs with the key alright maybe the problem isn't the 556L but the remote starter itself. I thought it was the bypass module because the led didn't flash when I tried to re-program it. If I pull the fuses does that clear the memory in the remote starter? When I try to make the transmitter re-learn (after removing and re-inserting the battery) nothing happens.
Here's some more weirdness... when I turn the engine off and close the door the courtesy lights stay on a minute. When the lights turn off my fuel guage creeps up to half full. When I open the door it drops back to empty.
extreme1
Posted: October 26, 2005 at 8:51 AM / IP Logged
You have something not wired right
I've never seen that happen before.
first thing I would do is remove the black wire from the 556L off the vehicles ORANGE / black and find a good solid ground for it.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
kgerry
Platinum - Posts: 3,455
Posted: October 26, 2005 at 9:08 AM / IP Logged
my friend i recommend you stop now and take it to a professional before you do serious damage to your vehicle..... i am not aware that the 555L loses programming if power is disconnected....if it did, i'm sure at least one or two of the hundred + i've installed would have come back by now because the customer disconnected his battery.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Moosetooth
Member - Posts: 10
Posted: October 26, 2005 at 7:59 PM / IP Logged
Thanks for the suggestions.  I found I didn't have the status monitor wire  connected properly.  556L re-programs fine now. Back to looking for the right parking light wire.....
Moosetooth
Member - Posts: 10
Posted: November 04, 2005 at 9:05 PM / IP Logged
Thanks everyone. . It might help someone else to know that I found out that, at least with my vehicle, how quickly I turn the key off and on is crucial to getting the module to program itself.
