2002 Chevy Blazer LS
layinframe_95
Member - Posts: 32
Posted: November 02, 2005 at 7:47 PM / IP Logged
I just installed an Alpine SEC-150R Alarm in my Blazer.  Everything seems to work fine except now my headlights don't work properly and I don't have a working "parking light flash" response when I arm/disarm the alarm.  The headlights turn on but the the drivers LOW beam is the only one that illuminates properly, the rest are just really dim, and all four bulbs come on at once.  The marker lights and bumper lights do not work, except when signalling or hazards are on, then the bumper lights work accordingly........  I am confused..... I have checked all my grounds, they all seem to be good.  Thinking maybe i hooked up a relay wire wrong somewhere....????
Any thought or suggestions are greatly appreciated!!!!
mo12v
Posted: November 02, 2005 at 7:50 PM / IP Logged
What type OUTPUT for Parking Lights does the Alpine have
MO
layinframe_95
Member - Posts: 32
Posted: November 02, 2005 at 7:52 PM / IP Logged
Positive output for the parking lights
mo12v
Posted: November 02, 2005 at 7:57 PM / IP Logged
Where did you hook it in at?
I usually go to the
Parking LampL BLUE (+)AT LIGHT SWITCH HARNESS
Behind Light Switch
MO
layinframe_95
Member - Posts: 32
Posted: November 02, 2005 at 8:10 PM / IP Logged
Thats exactly where I hooked into, right behind the actual switch you use to turn on the parking lights/ headlights.  the other thing that troubles me is that the tail lights flashed when I first installed ( no bulbs in front end cuz i was repairing from a deer I had hit).  But then I put my headlight/park light/marker lights in and clicked the arm button and nothing.  It did blow the 10amp fuse that is on the alarms light flash output wire.....
mo12v
Posted: November 02, 2005 at 8:23 PM / IP Logged
Are you sure there is NO Broken Bulbs or shorted wires on Front?
MO
layinframe_95
Member - Posts: 32
Posted: November 02, 2005 at 8:30 PM / IP Logged
I Replaced with all brand new bulbs, and just tonight I pulled all the wire loom off the headlight wires and all wires are visually fine.  have not used a DMM on the wires yet...
I really appreciate the help mo12v!!!
I'm gonna go DMM the wires....  Any other suggestions are appreciated....  :)
mo12v
Posted: November 02, 2005 at 8:44 PM / IP Logged
1 Your Battery, is it up & will vehicle Start?
2 Does you lights work if you Unhook wire from Alpine?
MO
layinframe_95
Member - Posts: 32
Posted: November 02, 2005 at 10:39 PM / IP Logged
I just got done removing my dash panels. I found the "park light Flash" wire was pinched and I fixed this.  Now the park lights and marker lights come on appropriately with the headlight switch, but still do not flash with the Arm/Disarm function.  Also all bulbs are very dim, except the Driver's Low beam which comes on full power.
1- The vehicle starts just fine, "pops" right off...
2- No, the lights do not change even with the wire from the alpine disconnected
nava94
Silver - Posts: 296
Posted: November 03, 2005 at 7:43 PM / IP Logged
replace the blown fuse on the alarm output for your lights and check your output too. recheck all your wires to make sure nothing else is pinched. check your fuses at the distribution block you might have blown a fuse.
Saturday, December 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
