2005 denali, alarm/remote start
masterk
Member - Posts: 19
Posted: March 22, 2006 at 4:54 PM / IP Logged
 2005 denali need remote start / alarm info  also would like info for window rollup will be installing aps596 with dei 457g databuss interface module also any tips that might be  helpful
8d
crawford7827@bellsouth.net
xscash
Copper - Posts: 317
Posted: March 22, 2006 at 5:38 PM / IP Logged
here you go....and there is a bypass that  will also do windows thru the databus...im not sure of which one it is
2005 GMC YUKON 4DR SUV
 Audio/Mobile Video
 WIRE  COLOR  POLARITY  LOCATION
 Battery  ORANGE  (+)  RADIO HARNESS
 Accesory
   THE RADIO HARNESS DOES NOT PROVIDE A SWITCHED POWER SOURCE. RUN A WIRE TO THE FUSEBOX FOR SWITCHED POWER. THE ACCESSORY TURN-ON AND AMPLIFIER TURN-ON ARE CONTROLLED BY THE CLASS 2 SERIAL NETWORK.
 Ground  BLACK/ WHITE  (-)  RADIO HARNESS
 Illumination  BROWN  (+)  RADIO HARNESS
 Dimmer  GRAY  (+)  RADIO HARNESS
 LF Speaker (+)  TAN
 LF Speaker (-)  GRAY
 RF Speaker (+)  LIGHT GREEN
 RF Speaker (-)  DARK GREEN
 LR Speaker (+)  BROWN
 LR Speaker (-)  YELLOW
 RR Speaker (+)  DARK BLUE
 RR Speaker (-)  LIGHT BLUE
 Steering Cntrls  OPTIONAL
   THIS VEHICLE MAY BE EQUIPPED WITH OPTIONAL ONSTARŽ TELEMATICS EQUIPMENT. USE AN APPROPRIATE INTEGRATION HARNESS OR INSTALLATION PROCEDURE TO ENSURE PROPER FUNCTION OF THIS EQUIPMENT.
 Speed Cntrl  OPTIONAL
 Radio Security  YES
 Security
 Battery  RED  (+)  IGNITION SWITCH HARNESS
 Ignition 1  PINK  (+)  IGNITION SWITCH HARNESS
 Starter 1  YELLOW  (+)  IGNITION SWITCH HARNESS
 All Door Trigger  GRAY/BLACK  (-)  AT MODULE IN DRIVERS DOOR
 Convenience
 LF Pk Lt Bulb  BROWN  (+)  AT FRONT LEFT PARKING LIGHT
 RF Pk Lt Bulb  BROWN  (+)  AT FRONT RIGHT PARKING LIGHT
 LR Pk Lt Bulb  BROWN  (+)  AT REAR LEFT PARKING LIGHT
 RR Pk Lt Bulb  BROWN  (+)  AT REAR RIGHT PARKING LIGHT
 Remote Start
 Ignition 2  WHITE  (+)  IGNITION SWITCH HARNESS
 Accessory 1  ORANGE  (+)  IGNITION SWITCH HARNESS
 Anti-Theft Type  GM PASSLOCK IIŽ ANTI-THEFT SYSTEM
 Anti-Theft Descript  THE BCM MODULE MUST SEE A SPECIFIC RESISTANCE VALUE BEFORE THE VEHICLE WILL START PROPERLY
 Tachometer  WHITE  (-)  AT IGNITION COIL
 Modules
 WIRE  LOCATION
 Please select another category
 Doorlocks/Windows
 Door Lock Circuit  CLASS 2 DATABUS
 Power Unlock  MUST USE A GM DATABUS INTERFACE MODULE  DATA  AT SWITCH ON RIGHT REAR ROOF PILLAR IN CARGO AREA
 PowerLock  LIGHT BLUE  (-)  AT SWITCH ON RIGHT REAR ROOF PILLAR IN CARGO AREA
 Driver Mtr Unlock  TAN  (REV)  DRIVERS DOOR
 Driver Mtr Lock  GREY  (REV)  DRIVERS DOOR
 Pas Mtr Unlock  TAN  (REV)  PASSENGER DOOR
 Pas Mtr Lock  GREY  (REV)  PASSENGERS DOOR
Twelvoltz
Platinum - Posts: 2,384
Posted: March 22, 2006 at 5:46 PM / IP Logged
XS, if you watch the video on Omega's site (caralarm.com) they show their module as being able to do rollup. However if you check their bypasskit.com site they make no mention of it. Is there another brand out there that can do this?
masterk
Member - Posts: 19
Posted: March 22, 2006 at 6:59 PM / IP Logged
 thanks for the info i'm looking forward to interfacing the data buss
8d
xscash
Copper - Posts: 317
Posted: March 22, 2006 at 8:10 PM / IP Logged
twelvoltz, im not sure... i try to use every product out there  at least once for testing....and i could swear ive seen that on more than 1 bypdonkey unit. but my memory may be wrong...but i think your right ,it was an omega peice.
masterk
Member - Posts: 19
Posted: March 23, 2006 at 8:58 AM / IP Logged
 recieved info to install remote start /alarm on 05 denali using aps596 and dei 457g interface it mentioed if equipped with on star use and appropiate intergration harness or installation procedure to ensure  proper function, can anyone supply info or steps to be taken to avoid problems with on star
8d
Platinum - Posts: 12,488
Posted: March 23, 2006 at 9:12 AM / IP Logged
The OnStar will only be affected if you remove the OEM radio system. Adding a remote starter or security system will not affect the functions or features of the OnStar system.
masterk
Member - Posts: 19
Posted: March 23, 2006 at 9:52 AM / IP Logged
are the windows controlled by the data buss if so is their a interface unit that you would recommend if not can i go to drivers windows switches and diode isolate each and connect all together to be controlled by 2 seperate channels for up & down,also should i use a diode with a rating higher than a 1n4001(prv) how much current will be drawn with all 4 windows operating at the same time or i could do just the front windows
8d
masterk
Member - Posts: 19
Posted: March 24, 2006 at 9:05 AM / IP Logged
 can someone tell me the wire color for data input @ diagnostic connector on 05 denali that will take single wire output from dei 457gw data bus interface also wire colors for front windows and can they be found @ drivers kick panel
8d
Posted: March 24, 2006 at 10:16 AM / IP Logged
Here is the plug that you need to tap into for the databus wire: The YELLOW square is the spot that you want to tap into for the databus wire.
<"http://www.velocitymotorsport.com/images/install_notes/databus_plug.jpg" border="0">
LEFT FRONT UP/DWN  dk. blue - brown C LF window switch in door
RIGHT FRONT UP/DWN  dk. blue - brown C RF window switch in door
LEFT REAR UP/DWN  dk. blue - brown C LR window switch in door
RIGHT REAR UP/DWN  dk. blue - brown C RR window switch in door
Saturday, April 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
