Compustar 2WFM8000-AS wiring
thesaint124
Member - Posts: 32
Posted: May 25, 2006 at 9:53 PM / IP Logged
Hey guys, got a little wiring question..... I have installed many DEI products, but this is my first compustart unit...
Off the main harness, I have a few wires I am unsure of...
Compustar 2WFM8000-AS wiring -- posted image.
The Green / Red (actually 2 seperate wires from the same Pin in the CN1 harness) says they are for ignition. how are these suposed to be wired. I am installing into a car with a 2nd ignition, but I thought the pre-wired relay was for second ign, acc, or starter? and the other one is the red / white wire, how do I wire this for the second ignition option?
now for the 2 relays...
on the first relay I have a violet, and blue wire. how do I wire this for a 2nd ing?
and the sond relay (the starter kill - anit grid) there is a yellow, and yellow black. I am used to cutting the starter wire, and wiring those up, but which is the key side and which is the starter side??
thanks for your help guys.... I guess I was just spoiled by the DEI install manuals.... heh heh
regards,
thesaint124
Member - Posts: 32
Posted: May 26, 2006 at 2:06 AM / IP Logged
ok after some thinking, my only realy problem is this:
How is this wired for a second ignition?
thanks guys, Mark
thesaint124
Member - Posts: 32
Posted: May 26, 2006 at 2:09 AM / IP Logged
ok, I hate to keep posting like this, but I can't seem to edit my posts...
Is this correct.... I would wire either the (-) starter, (-) acc, or (-) ignition outputs from the CN2 harness to the violet wire, to activate that signal on the blue wire?
Mark
KarTuneMan
Platinum - Posts: 7,056
Posted: May 26, 2006 at 4:02 AM / IP Logged
pin 87 of the relay gets 12v constant........pin 30 get's  acc. starter or  ign.
look for the pin posistion's on this site
thesaint124
Member - Posts: 32
Posted: May 26, 2006 at 4:51 AM / IP Logged
so using the wiring from the compustar brain unit, Pin 86 would get 12v constant as well, and pin 85 would get the (-) ignition, to produce ignition on pin 30.... correct?
Mark
Platinum - Posts: 12,488
Posted: May 26, 2006 at 8:50 AM / IP Logged
The GREEN goes to the ignition at the ignition harness on the car. THe other red wire is suppose to go to a relay.
Purple wire goes to the CN2 harness for one of the 2nd device ( IGN, ACC or STARTER ) and the BLUE wire goes to the 2nd device wire on the vehicle.
regards,
[/QUOTE]
YELLOW goes to the starter and YELLOW/BLACK goes to the key side
djlayz
Copper - Posts: 104
Posted: May 26, 2006 at 10:13 AM / IP Logged
I had the same problem as you when I installed mine then i went to this link and it solved all my problems. https://www.the12volt.com/uploads/files/CM3000_wiring_manual.pdf
