2006 Chevy Express Van Passlock
Brad Eyben
Member - Posts: 33
Posted: October 29, 2006 at 7:09 PM / IP Logged
I installing a compustar starter alarm in a 06 Express and am using a 556LW module.The van cranks and then immediatly shuts down with the security light flashing.I'm not sure what to try next, I've confirmed connections for the module, checked for a ground signal on the status input while cranking, LED's indicate that it has learned the code, resistance sense wires are correct.One thing I am assuming is that this is Passlock 2 not Passlock 1.
Thanks for any suggestions.
Brad
doibuy
Copper - Posts: 177
Posted: October 29, 2006 at 7:34 PM / IP Logged
Yes it is a Passlock II system.  Recheck your connections verifying the Passlock II setup.
audiopro111
Copper - Posts: 160
Posted: October 29, 2006 at 7:36 PM / IP Logged
i belieive that truck is actually passlock 3 , look at your key at the blade does it say pk3  on the blde if it does than u have an imobilizer key and that means you'll need an extra key and a imobilizer bypass module ,a lot of chevys and gm's are coming with chipped keys not too many with passlock lately
AudioPro111
Brad Eyben
Member - Posts: 33
Posted: October 29, 2006 at 7:43 PM / IP Logged
Thanks for the replies guys.I think I may have found the trouble...When I cut the wire for the keysense, the truck will still start. I must have the wrong wire. Am using the diagram for a 05, It says the lt. green wire at the harness. There is 2 lt. green wires and the truck starts with both of them cut.Does anybody know which wire is the keysense on a 2006?
Thanks,
Brad
audiopro111
Copper - Posts: 160
Posted: October 29, 2006 at 9:47 PM / IP Logged
last i checked it lt.grn but to verify with a test light it will show ground when key is in ignition and low voltage when key is out of ignition cylinder
AudioPro111
joescarstereo
Member - Posts: 8
Posted: October 29, 2006 at 11:29 PM / IP Logged
Aother easy way to see the problem is to totally take off the colum cover, techsoft cant always be correct these cars arent all the same and that would reveil the wires right to there source.
The Car show Kings
f150fan
Copper - Posts: 95
Posted: October 30, 2006 at 11:56 AM / IP Logged
The passlock wire colors for that van should be yellow and tan. You should not need keysense for the 556lw to work.
Brad Eyben
Member - Posts: 33
Posted: October 30, 2006 at 12:06 PM / IP Logged
I'm not sure what you mean by not needing keysense. The installation instructions clearly show the keysense wire interupted.
Anyway, I took the column shroud off and discovered 3 wires,... yellow,tan and red with white stripe. Any ideas which one puts out the resistance value I need?
Thanks,
Brad
kgerry
Platinum - Posts: 3,455
Posted: October 30, 2006 at 12:24 PM / IP Logged
i have never hooked up keysense to do PL II.....   PK3, yes.... PLII nope......
yellow is usually your passlock data/value wire....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Brad Eyben
Member - Posts: 33
Posted: October 30, 2006 at 1:09 PM / IP Logged
Sorry I must be using the wrong terminology, I mean the wire providing resistance info from the passlock.
I'll try the yellow, thanks.
Brad
Page of 3
