2005 Grand Cherokee problems
azn_fcuk
Copper - Posts: 104
Posted: November 14, 2006 at 11:13 PM / IP Logged
I just installed a compustar 2way starter only into this beautiful truck. Now when i remotley start the vehicle the Traction Control light stays on, and the on board computer reads "problem with electronic brake" when i start with key im fine.
Ive checked all my resistence's and their bang on. Also I wirred my 2nd starter and Accessory just like this http://64.85.6.129/extrainfo/diagrams/26500_GRAND-CHEROKEE_CHRYSLERS%20STARTER%202%20AND%20ACCESSORY%20DIAGRAM.pdf
Now i used universal bypass for transponder and a CAN SL for my anti theft and accessorys.
Im also getting positvie feed back into my Ground in while Running wire, Door locks, and Trunk release.  I diode isolated my Ground in while running wire and my 2nd starter wire.
IM SO CONFUSED
tha
azn_fcuk
Copper - Posts: 104
Posted: November 15, 2006 at 11:51 AM / IP Logged
any takers
Hymer
Silver - Posts: 695
Posted: November 15, 2006 at 1:36 PM / IP Logged
Where are you pullung your main 12v supply from.... if it's from lt blu and red it could be causing a problem.. ran into that before.. Pull your main power directly from tha battery... personally I would go with the bypass that takes care of all the chrysler bs with resistors and second starter outputs and such... It works great.. saves a lot of headaches
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
azn_fcuk
Copper - Posts: 104
Posted: November 15, 2006 at 2:28 PM / IP Logged
I went right to the battery.
I used the CanSL which takes care of all features like door locks and such, which is why i cant figaure out where the feed back is comming from
damn
kgerry
Platinum - Posts: 3,455
Posted: November 15, 2006 at 3:00 PM / IP Logged
sounds like you may have missing powering an extra ign or acc wire... which did you power?
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
azn_fcuk
Copper - Posts: 104
Posted: November 15, 2006 at 4:00 PM / IP Logged
I powerd ign, acc is relayed with resistor, the same with 2nd starter.
hmmm
kgerry
Posted: November 15, 2006 at 4:58 PM / IP Logged
should be ok then... i always use a PKU-CH2GX  and dont bother with the relays and resistors and i havent had any issues....
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
azn_fcuk
Copper - Posts: 104
Posted: November 15, 2006 at 5:17 PM / IP Logged
the 2nd starter and acc are negative on the data wire right?  it does need a relay.
or are you saying that bypass will accomodate for neg 2nd starter and acc with the probper resistance?
Hymer
Silver - Posts: 695
Posted: November 15, 2006 at 5:20 PM / IP Logged
no resistors are needed with the bypass... 2nd start or accy
kgerry
Posted: November 15, 2006 at 5:25 PM / IP Logged
PKU-CH2GX  allows for 2nd start and 2nd acc with built in resistors,,,, bypasses 1st and 2nd gen Sentry key...also disarms oem alarm.... sweet little module....
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
