1998 Cavalier, alarm/remote start
black cavy
Copper - Posts: 78
Posted: November 21, 2006 at 8:32 AM / IP Logged
Is there a way to get to the Keysense wires with out takeing off steering wheel shroud(plastic thing)
I think i can get the Ign wires in a big loom under the dash but didn't know about the keysense wires.
Also well were still here,where is a good place to mount the brain,i know its a very open under there.
black cavy
Copper - Posts: 78
Posted: November 21, 2006 at 8:46 AM / IP Logged
Also this car doesn't have power locks so im adding them
He wants truck pop,but do i need to go all to the trunk.would i find it like on the Keyless cars in a wire in the kickpanel.
Could some please draw me a realy as well,the alarm output is (-) and it says the trunk is (-)
black cavy
Copper - Posts: 78
Posted: November 21, 2006 at 10:08 AM / IP Logged
Hi all i hope i word'ed in right
the car is a 1998 Cavailer
I need a diagram to wire up a (-) trunk pop,can't seem to find one at all
also do i need to go right to the trunk latch or can i get the wire in the kickpanel like on the keyless cars.
any help would be grat.
spookiestylez
Silver - Posts: 531
Posted: November 21, 2006 at 10:43 AM / IP Logged
1998 Cavalier, alarm/remote start -- posted image.
Yeah, you should be able to get the wire you need in the kick panel.Also be sure to use a DMM to test all your wires
GL
sS
rtfm
black cavy
Copper - Posts: 78
Posted: November 21, 2006 at 11:52 AM / IP Logged
GL
sS
Don't i need to use pin 30 for the device as thats the comon pin,i see (12v) and Neg output and ground
Or do i use 87a for to activate the trunk wire
black cavy
Copper - Posts: 78
Posted: November 21, 2006 at 11:55 AM / IP Logged
GL
sS
Do i use pin 87a to activate the trunk pop wire then
because i see 12+, neg out and ground
also isit pin 30 the common pin,woulded that go to the trunk wire
spookiestylez
Silver - Posts: 531
Posted: November 21, 2006 at 2:24 PM / IP Logged
Your trying use something that has a (+) output to pop your trunk which is (-), if that is correct you can wire up a relay like shown above.I normally would tell you to have the (+)trigger input to 85, and have both 87, and 86 to ground...that would give you a (-) output from 30. either way is the same effect, just the12volt.com's pic was easier to use than making one of my own.hopefully that helps ya out.
rtfm
KarTuneMan
Platinum - Posts: 7,056
Posted: November 21, 2006 at 2:49 PM / IP Logged
The key sence on this rig is in the black conector on the ign. harness.
Your trunk pop only comes on the cars with keyless entry (factory) it's found in the trunk. Behind carpet left sied of trunk. blk/wht POS(+)
hotwaterwizard
Silver - Posts: 1,350
Posted: November 21, 2006 at 10:18 PM / IP Logged
So that you understand what pin does what. Here is an internal diagram.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
black cavy
Copper - Posts: 78
Posted: November 21, 2006 at 11:03 PM / IP Logged
Alright i was just going over all my wireing info and yes the factory trunk wire is (+) and the output from the RS is a (-).
So that diagram posted above will work just fine
Page of 3
Monday, November 3, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
