1999 Explorer transponder key
Scott35
Silver - Posts: 258
Posted: January 27, 2003 at 5:09 PM / IP Logged
I have a 1999 Ford Explorer, only have 1 chip key, do I have to have 2 programmed keys to program new ones, or will 1 be sufficient?
Tacomacrew
Player69
Silver - Posts: 504
Posted: January 27, 2003 at 5:14 PM / IP Logged
You need at least 2 to program a 3rd.  You will need to take it to your ford dealer to get a 2nd key cut and programmed.  You will also likely need make an appoinment as their software makes them wait 10 minutes after hooking it up.  You are likely looking at 20mins to 30 mins labour to do this as well.  Not to mention they will soak you about $50 for key and cutting.  You can also get blank keys from companies like Curtis for a better price.
securinu
Silver - Posts: 772
Posted: January 27, 2003 at 5:24 PM / IP Logged
if you need a key let me know i can get transponder keys for about $25 shipped
securinu
Silver - Posts: 772
Posted: January 27, 2003 at 5:26 PM / IP Logged
although you will still have to have them code in the transponder . and take the key to get cut for like $5 so you will save at least $20
Scott35
Silver - Posts: 258
Posted: January 27, 2003 at 8:17 PM / IP Logged
Thanks guys
Tacomacrew
sickstyles
Member - Posts: 34
Posted: January 29, 2003 at 5:19 PM / IP Logged
i have a similar problem and was wondering if i can by-pass the system all together?
slobert
Member - Posts: 31
Posted: January 29, 2003 at 6:49 PM / IP Logged
ya, you can bypass it....   555U lol
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
