remote starter, 1999 diesel suburban
jvanderkruk
Posted: December 12, 2006 at 12:36 PM / IP Logged
Greetings.
I am about to install a 'pro start' keyless remote to a 1999 diesel suburban.
1.  Should I have any reason to reconsider this install or is it pretty straight forward?
2.  Can anyone give me some practical tips or wiring diagrams to expedite the job?
3.  I have heard of a 'BCM'  what is this & do I need to make use of it?
4.  Do I need a GM bypass passlock for this install?
5.  Are there any other words to the wise?
Thank you for your help & advice in advance.
Regards,
John Vanderkruk
05gt
Silver - Posts: 628
Posted: December 12, 2006 at 12:51 PM / IP Logged
to answer some of the questions, the install is pretty basic if you have had any experience installing
cause the truck is diesel you need to hook up the wait to start wire, this wire will tell the remote starter to start the truck when that light goes out on the dash, you also need to hook up the 2nd ignition wire in the vehicle or there could be some problems
the bcm in your application will not be needed as there are no wires there that you need
yes you do need a bypass for this vehicle
other people will add some of there info
jvanderkruk
Posted: December 12, 2006 at 1:39 PM / IP Logged
Thank you.
If anyone can point me to a wiring diagram for the '99 GMC diesel Suburban I would be grateful!
Regards,
John Vanderkruk
KarTuneMan
Platinum - Posts: 7,056
Posted: December 12, 2006 at 1:52 PM / IP Logged
 Wire/Function Colour Location/Description Polarity
 PASSIVE ANTI-THEFT YES PASSLOCK 2   SEE NOTES
 12 VOLTS Red Ignition harness   +
 IGNITION Pink Ignition harness   +
 IGNITION 2 White Ignition harness   +
 The truck's 2nd ignition wire must be connected or the check engine light will come on and serious transmission damage may result.
 ACCESSORY Orange Ignition harness   +
 STARTER Yellow or Purple Ignition harness   +
 KEY SENSE Lt.green Ignition harness   -
 TACH SIGNAL White At coil on engine   AC
 DIESEL TACH SIGNAL White At alternator on engine   AC
 LOCK Lt.blue At relay above gas pedal   +
 UNLOCK White At relay above gas pedal   +
 GLO-PLUG SIGNAL Blue Any glow-plug on engine or light   +
 DOORPIN Purple At light switch harness   -
 TRUNK PIN Common with doors
 TRUNK RELEASE Black At release switch in dash   +
 BRAKESWITCH White At switch above brake pedal   +
 PARKLIGHTS Brown At light switch harness   +
 HAND BRAKE Lt.blue On parkbrake bracket   -
 HORN Black At steering column harness   -
PASSLOCK DATA Yellow In 3 wire harness from ignition switch   DATA
 PASSLOCK GROUND Black or ORANGE / black In 3 wire harness from ignition switch   -
jvanderkruk
Posted: December 12, 2006 at 2:58 PM / IP Logged
thank you again!
I have a 555U    Universal Transponder anti-theft bypass.  Can I use it on the '99 GMC diesel Suburban?
Regards,
John Vanderkruk
xtremej
Gold - Posts: 1,440
Posted: December 12, 2006 at 3:54 PM / IP Logged
No, you need a passlock II bypass. PLJX,PLXR, 555lw, GMBP are to name a few.
jvanderkruk
Posted: December 13, 2006 at 10:58 AM / IP Logged
Thanks.
Does anyone hesitate to use the 'pro start' remote starter?  I spoke with an installer yesterday who will only use 'viper' remote start.
Thank you for your comments in advance.
Regards,
John Vanderkruk
