valet 561t, 2007 F350 diesel
rnemtb
Copper - Posts: 70
Posted: December 30, 2006 at 2:30 PM / IP Logged
 Hi, iam installing a valet 561t in a 2007 ford f350 diesel is the install guide for the 561r the same? i took the r/s out of the customers 2004 excursion. i searched the site but could only find the561r guide.
thanks and happy new year to all
george
rnemtb
swamprat323
Gold - Posts: 1,335
Posted: December 30, 2006 at 6:00 PM / IP Logged
its already in the download sectiosn on this site.
download section
rnemtb
Copper - Posts: 70
Posted: December 31, 2006 at 12:13 PM / IP Logged
  thanks for the help swamprat323, i must haved missed it. i have it now
rnemtb
rnemtb
Copper - Posts: 70
Posted: January 08, 2007 at 11:24 AM / IP Logged
 hi , installing a valet 561t r/s to a 2007 F350 diesel, took r/s out of 2004 excursion.the only wires that were hooked up in excursion are:
heavy wires as normal at ignition harness
ground
white - parking lights
WHITE/ red-? in kick panel
customer was using ford factory remotes with 3 pulse trigger. my questionis the WHITE/ red wire does this attach to the blk/light blue in kick panel for the door trigger ,will be using ford factory remotes on 2007 F-350.
thanks
george
rnemtb
actypes
Member - Posts: 17
Posted: January 08, 2007 at 11:41 AM / IP Logged
no, the door trigger wire does not control the activation of the 561t.  Remember, if your using the factory remote the WHITE/ red ALWAYS goes to the lock motor wire.  Just the lock wire will not do the job.  Use a thick pink/black in the driver kick.  Test by probing the pink/black and pressing the lock button on the factory remote. Should pulse pos.
actypes
Member - Posts: 17
Posted: January 08, 2007 at 11:45 AM / IP Logged
Your also going to NEED to use a pulse timer to delay the starting of the trunk.  You cannot use the wait-to-start wire.  Hopefully you know about the glow plugs and why this is necessary
rnemtb
Copper - Posts: 70
Posted: January 08, 2007 at 11:50 AM / IP Logged
thank to all i am using a 528t pulse timer already attached.
        george
rnemtb
Tuesday, January 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
