dei529t i think i got it almost.
slawson2000
Member - Posts: 47
Posted: July 15, 2007 at 5:29 PM / IP Logged
I want to hook up a DEI529 to my ESP150 in my Bronco to operate the rear window with the AUX button on my remote.  I would really like it to go down by the remote, going up would be nice too.
This is what I have come up with so far.  I think I can install it between the Master Tailgate Switch and the Tailgate Switch.
Wiring (per the diagram below)
DEI 529T                 Truck
Blue                         Motor side P/LG
Gray                         Nothing
Brown                     Switch side P/LG
Orange                   ESP150 H1/12 RED / wht
Black                       Ground
Gray/Blk                  Nothing
Red                          12V (+)
ORANGE / Blk             Don't know
Green                      Motor side PK/LB
White                       Switch side PK/LB
dei529t i think i got it almost. -- posted image.
So the questions I still have...
Is this right?  Will it work if installed between he switches?
How do I hook up the 2nd Activation Input to make the window go up?
Thanks in advance...
Big Dog
Gold - Posts: 1,265
Posted: July 16, 2007 at 12:06 PM / IP Logged
Do the wiring between the switch and the motor.
Cut Yellow/Red.
Connect Brown of 529T to Yellow/Red from switch.
Connect Blue of 529T to Yellow/Red from motor.
Cut RED / Yellow.
Connect White of 529T to RED / Yellow from switch.
Connect Green of 529T to RED / Yellow from motor.
Ground signal on Orange will close until signal is turned off or released.
Connecting Gray to Orange will close with a ground pulse on Orange.
Ground signal on ORANGE / Black will open until signal is turned off or released.
Connecting Gray/Black to ORANGE / Black will close with a ground pulse on ORANGE / Black.
And finally the obvious: Red = B+, Black = Ground.
Prepare your future. It wasn't the lack of stones that killed the stone age.
slawson2000
Member - Posts: 47
Posted: July 16, 2007 at 1:17 PM / IP Logged
Thanks for getting back.  I kind of figured it was headed the way of wiring it in back, but that is OK.  I got it all until:
I'm a newbie and need a little more explanation of the above as to where and on what do those wires go.  Somehow it it not sinking in...
Big Dog
Gold - Posts: 1,265
Posted: July 16, 2007 at 1:46 PM / IP Logged
When you hold the Orange wire to a ground, the motor will turn until you remove the Orange from the ground. This allows you to roll it part way and stop it at any time.
If you want the window to move all the way up or all the way down by just sending a quick pulse to the Orange or ORANGE / Black, then you need to connect the Gray and Gray/Black as mentioned previously.
This is because 529T will send out a constant ground on the Gray and Gray/Black when you just pulse the orange.
So connecting the Gray to Orange causes the module to self feed a ground to itself.
slawson2000
Member - Posts: 47
Posted: July 16, 2007 at 2:24 PM / IP Logged
The fog is starting to clear.
Now, I can see wiring it to roll down, but where (how) do i wire it to to the ESP150 to roll up as well?
Or am I limited by the ESP150 to pick one one option?
Big Dog
Gold - Posts: 1,265
Posted: July 16, 2007 at 3:26 PM / IP Logged
The RED / White on the ESP is the only usable channel, so, use it to roll down.
If momentarily grounding the Orange of the 529T nudges the window up then connect it to the Orange from the 150 ESP to roll up. The Orange from the 150ESP is a Ground when armed signal which will roll the window all the way up the instant you press the lock button on the remote.  Don't connect the Gray of the 529T to anything.
slawson2000
Member - Posts: 47
Posted: July 16, 2007 at 4:02 PM / IP Logged
Ooooo... we are getting close.
So if I hook up the RED / wht I should be able to push the aux button on the remote once and the rear window will go down - right?
And by hooking up the orange wires, when I lock the doors with the remote the window should go up.  I have a couple diodes in there and have a DEI629R hooked up as well.
https://www.the12volt.com/installbay/forum_posts.asp?tid=95114&KW=scanning
Would I need another diode in there as well?
Big Dog
Gold - Posts: 1,265
Posted: July 19, 2007 at 9:40 AM / IP Logged
Using the aforementioned wiring scheme, if you connect the RED / White to the ORANGE / Black and press the aux button, then the window motor will turn until you release the aux button at which point the window will stop.
As for the up (close) direction, yes connect the Oranges together. Put a diode on the between the starter kill relay and the security system's Orange wire. Connect the 629 and the 529 to the Orange directly at the security system so there is no feedback from the starter kill relay's coil.
This should do it.
slawson2000
Member - Posts: 47
Posted: July 19, 2007 at 10:32 AM / IP Logged
I shall try and let you know how it works...
slawson2000
Member - Posts: 47
Posted: July 19, 2007 at 3:55 PM / IP Logged
New problem - Mounting location.  The unit looks like it will not hold up in any of these nook and crannies I can find in the back.  Am I wrong or can these things take a location like behind a tail light housing?
