will using factory arm/disarm work?
tgreaves
Member - Posts: 21
Posted: July 18, 2007 at 4:11 PM / IP Logged
When installing a compustar alarm.. Is it possible to use the arm/disarm output wires to arm/disarm the factory alarm and thus not need to hook up the door lock/unlock wires from the compustar unit?
Basically is there any problem with letting the factory alarm lock/unlock the doors instead of direct from the compustar alarm?
mikvot
Gold - Posts: 1,043
Posted: July 18, 2007 at 5:13 PM / IP Logged
I would hook the door lock wires up to the arm and disarm of the car, and forget about the arm and disarm off the compustar. This is assuming that arm and disarm of the vehicle will lock and unlock the vehicle. Alot is gonna depend on what kind of vehicle you have.
tgreaves
Member - Posts: 21
Posted: July 20, 2007 at 8:56 AM / IP Logged
Actually I hooked up majority of the alarm lastnight so I just hooked up the lock/unlock wires of the compustar to the power lock/unlock wires of the car and also hooked the compustar arm/disarm output wires to the arm/disarm wires of the factory alarm..
xtremej
Gold - Posts: 1,440
Posted: July 20, 2007 at 9:59 AM / IP Logged
Make, model and year, will get you the info you desire.
Wednesday, April 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
