finding post, latching relay
seeker1
Member - Posts: 24
Posted: December 20, 2007 at 1:13 AM / IP Logged
Acouple weeks ago I was searching posts looking for a discrete approach for a latching relay w / momentary trigger. I found 1 using a ZXMP6A13F P-channel Mosfet and a CD4027B master J K flip flop. Now I can't find any more. As i remember this setup took a momentary pulse to trigger the flip flop and would remain on until triggered to off by a door switch. Does anybody know which post this was or how to set this up? I want to toggle on / off with my remote & trigger to off when the door opens.
Only the strong survive.
Eat the weak.
dualsport
Silver - Posts: 983
Posted: December 21, 2007 at 10:38 PM / IP Logged
Boy, you sure remembered a lot of details from that post, figured if you could remember all that, the link should have been cake- especially for a seeker finding post, latching relay -- posted image.
latching relay
dualsport
Silver - Posts: 983
Posted: December 21, 2007 at 10:45 PM / IP Logged
Not sure if that circuit matches what you're looking for though, that one toggles the output every time a pulse is received. Sounds like you want something with another input to reset the output (when you open the door), along with a pulse input to toggle it on and off.
You can use the set or reset inputs on the flip flop to do it, should be easy enough.
ralphtonka
Member - Posts: 30
Posted: December 21, 2007 at 10:59 PM / IP Logged
simple 12v mechanical latching relay (electronics wholesaler $4), use door trigger w/ diodes to trip off, & pulses from unit to toggle
hotwaterwizard
Silver - Posts: 1,350
Posted: January 06, 2008 at 1:37 AM / IP Logged
Here is a simmular circuit.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
hotwaterwizard
Posted: January 06, 2008 at 1:48 AM / IP Logged
Here is another one.
http://www.circuit-innovations.co.uk/push_switch.html
Stockton California
Tuesday, June 24, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
