relay diagram planning advice needed
defnu
Member - Posts: 15
Posted: June 12, 2009 at 12:41 PM / IP Logged
hello.
i'm working on removing key cylinders for my doors (completed) and ignition.
i already have a keyless entry alarm system that i had to learn to install myself.  my end goal is to learn about wiring basics and relays are where i'm at right now. i wired the relays to my door locks but i guess that's not enough relay work for me to remember by heart.
ANYWAYS! below is a diagram of my ignition system.  i have a diagram for the starter button (does not incorporate a connection with WHT (BAT -a).
i am left with wiring the ACCssories (I) and the ON (II) switch to a three option toggle (off, option a, option b)
how can i acheive this with the least amount of relays? thanks for any input.
[IMG]https://i272.photobucket.com/albums/jj173/defnu/IGN.jpg[/IMG]
hello.
defnu
Member - Posts: 15
Posted: June 12, 2009 at 1:04 PM / IP Logged
relay diagram planning advice needed -- posted image.
hello.
defnu
Member - Posts: 15
Posted: June 12, 2009 at 1:05 PM / IP Logged
sorry for my noob posts, but if you have an idea just label the wires A-G
hello.
KPierson
Platinum - Posts: 3,527
Posted: June 12, 2009 at 1:26 PM / IP Logged
You should be able to do it with 5 relays (one relay for each switched wire) and 9 diodes.  The diodes will prevent backfeeding from position to position.
relay coil A = WHITE/ black
relay coil B = WHITE/ blue
relay coil C = BLACK / YELLOW
relay coil D = yellow
relay coil E =  BLACK/ white
So -
Switch Output 1 --> Diode --> relay coil A
Switch Output 2 --> Diode --> relay coil A
Switch Output 2 --> Diode --> relay coil B
Switch Output 2 --> Diode --> relay coil C
Switch Output 2 --> Diode --> relay coil D
Switch Output 3 --> Diode --> relay coil C
Switch Output 3 --> Diode --> relay coil E
Then you would just need to make sure the correct output is wired to the correct battery source.
Kevin Pierson
defnu
Member - Posts: 15
Posted: June 12, 2009 at 2:06 PM / IP Logged
So -
nice, thanks! i've never worked with diodes but i'm going to look that up.  is there some kind of rating i should look for? i'll be reading up regardless, thanks much again!
hello.
KPierson
Posted: June 12, 2009 at 4:54 PM / IP Logged
1A diodes will be adequate for your application
Kevin Pierson
Posted: June 13, 2009 at 2:05 AM / IP Logged
Anyone thought about (possible) factory transponder, steering lock etc etc etc. Fun, possibly expensive, lots of extra wiring etc. etc.
defnu
Member - Posts: 15
Posted: June 13, 2009 at 2:44 PM / IP Logged
hopefully this will work. thanks for the conformation.
i'm also in the market for a single toggle switch that can handle both "ACC" and "ON."  i'm just not sure what the tabs for wire mounting would look like.  would this switch be called a dpdt?
also, what websites are good for relays and switches? i'm in elk grove california and there is not anything local with a reasonable price.  the only thing radioshack had in stock were spst relays for $7.00 plus tax (CAlifornia) a piece!? i remember getting them for less than $5 from autozone and those came with pigtail harness' for the relay AND were spdt!
hello.
defnu
Member - Posts: 15
Posted: June 13, 2009 at 2:49 PM / IP Logged
also, i don't know where to place the 1amp diodesrelay diagram planning advice needed -- posted image.
hello.
defnu
Member - Posts: 15
Posted: June 13, 2009 at 2:50 PM / IP Logged
lol, i also don't know if thats the correct way to place the fuse or the correct fuse....im such a noob!
i did try my best to write out a clean diagram though.
hello.
Page of 3
