2002 Chrysler Sebring Alarm/Remote Start Wiring
sickstyles
Member - Posts: 34
Posted: February 19, 2004 at 11:45 AM / IP Logged
Im installing a remote starter in 2002 sebring 4dr. I cant find the tach wire or a few of the ignition accesory wires i need, if anyone has any information on the car or the colors of the wires please help me out.
thanks, andy
boomer_106
Silver - Posts: 710
Posted: February 19, 2004 at 12:19 PM / IP Logged
Does this help?
Chrysler
Sebring Sedan
2001-2002
Remote Starter Wiring Colors and Notes
Function
Vehicle Color
Location
Start:
YELLOW
IGNITION SWITCH HARNESS
Ignition #1:
BLUE
IGNITION SWITCH HARNESS*
Ignition #2:
GREEN/ RED (SMALL)
Ignition #3:
N/A
Accessory:
BLACK/ ORANGE & BLACK/ WHITE
Brake Light:
WHITE/ TAN (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:
ANY WIRE AT COIL OR INJECTOR
THAT IS NOT GREEN OR LT. GREEN
Parking Lights:
BLACK / YELLOW (+)
AT HEADLIGHT SWITCH
Headlights:
PURPLE / WHITE (+)
AT HEADLIGHT SWITCH
OEM Alarm Disarm:
LT. GREEN/ ORANGE
IN A # PIN CONNECTOR AT BCM **
OEM Alarm Arm:
LT. GREEN/ ORANGE
Diesel Glow Plug:
N/A
Clutch Bypass Wire:
N/A
Notes:
* This Vehicle Is Equipped Wiith Chrysler's Smart Key Engine Immobilizer. Use Universal Alarm Bypass Module part # 2x402 where X can be any number. **The Body Control Module (BCM) is attached to the fuse/relay box at the end of the dash on the drivers side.
Chrysler
Sebring Sedan
2001-2002
Alarm and Keyless Entry Wiring Colors and Notes
Function
Vehicle Color
Location
Constant +12 Volts:
PINK/BLACK
Starter Kill:
YELLOW
Ignition +12 Volts:
BLUE
Dome Lights/Superv:
TAN & TAN/RED (-)
OEM Horn:
BLACK/ RED (-)
STEERING COLUMN HARNESS
Power Lock:
WHITE/ GREEN
IN A # PIN CONNECTOR AT BCM ** ' ***
Power Unlock:
WHITE/ GREEN
Trunk Release:
BLACK/ WHITE (5-WIRE)
Alarm Input Wire:
TAN & TAN/RED (-)
Notes:
*** Lock is positive trigger through a 1800 ohm resistor. Unlock is positive trigger through a 750 ohm resistor.
sickstyles
Member - Posts: 34
Posted: February 19, 2004 at 12:47 PM / IP Logged
Thanks for the wiring info, as for the bypass. I purchased a dei 555U. What company makes the one you described, or is it something i can build with resistors?
boomer_106
Silver - Posts: 710
Posted: February 19, 2004 at 12:59 PM / IP Logged
I believe its made by design tech. Since you already bought one I would just use what you have provided its the correct one for your vehicle.
