2000 Pontiac Grand Am Keyless Entry
chaos6401
Member - Posts: 28
Posted: January 03, 2005 at 11:37 AM / IP Logged
I need install diagrams for a 2000 Pontiac Grand AM SE to hook up a rattler keyless entry system. If someone works at Bestbuy, could they help me out with the install guide or anybody else. thanks
KarTuneMan
Platinum - Posts: 7,056
Posted: January 03, 2005 at 5:27 PM / IP Logged
chaos6401
Member - Posts: 28
Posted: January 04, 2005 at 4:36 PM / IP Logged
is there an easy way to remove the radio to get to the ignition harness
chaos6401
Member - Posts: 28
Posted: January 04, 2005 at 4:38 PM / IP Logged
also whats the difference between the lock and unlock wires compared to the door triggers?
mobileworks
Copper - Posts: 136
Posted: January 06, 2005 at 6:28 PM / IP Logged
easy way to remove radio??? Remove shifter trim and pull out on heater / radio trim  unbolt radio and pull out.  May need to cut some of the plastic to get access to the ignition wires....
I like to unplug them from the switch and pull them out of the dash for easy access.
The door locks are connected totally different than the door locks....door locks require wiring in relays and resistors 1/4 watt resistors will work fine and the door triggers are just diode isolated....3 amp diode works well...
chaos6401
Member - Posts: 28
Posted: January 07, 2005 at 9:14 AM / IP Logged
Does anyone know the purpose of the door trigger?
mobileworks
Copper - Posts: 136
Posted: January 07, 2005 at 10:16 PM / IP Logged
some units require that the door pin/trigger input wires be connected to the vehicle for programming purposes...
Or if the unit is an alarm ...the alarm needs to know when the doors are opened to sound the alarm...
If your connecting a rattler keyless entry only, then you don't need to connect door trigger wires...however if its a full alarm keyless then yes you do need to connect them.
If its a keyless remote start then no you do not need to connect them....
If your unit has door trigger inputs then more than likely its a full alarm, and you will need to connect the appropriate door pin wires to the unit.
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
