2011 Toyota Sienna Alarm/Remote Start Wiring
jolt435
Posted: June 08, 2010 at 6:53 AM / IP Logged
Does anyone know where I can get the alarm wiring diagram for a 2011 toyota sienna?
chev104275
Gold - Posts: 1,427
Posted: June 10, 2010 at 8:15 PM / IP Logged
2011 TOYOTA SIENNA MINIVAN WITH 2.7L ENGINE AND 4-SPEAKER AUDIO SYSTEM
Security
WIRE COLOR POLARITY LOCATION
Battery RED OR WHITE (+) IGNITION SWITCH HARNESS
Ignition 1 YELLOW (+) IGNITION SWITCH HARNESS
Starter 1 RED (+) IGNITION SWITCH HARNESS
All Door Trigger VIOLET (-) AT BODY CONTROL MODULE ABOVE PARKING BRAKE PEDAL BEHIND DRIVERS SIDE OF DASH
Domelight Super VIOLET (+) AT BODY CONTROL MODULE ABOVE PARKING BRAKE PEDAL BEHIND DRIVERS SIDE OF DASH
LF Latch PINK (-) AT BODY CONTROL MODULE ABOVE PARKING BRAKE PEDAL BEHIND DRIVERS SIDE OF DASH
RF Latch GRAY (-) AT BODY CONTROL MODULE ABOVE PARKING BRAKE PEDAL BEHIND DRIVERS SIDE OF DASH
LR Latch GRAY (-) AT BODY CONTROL MODULE ABOVE PARKING BRAKE PEDAL BEHIND DRIVERS SIDE OF DASH
RR Latch BLUE (-) AT BODY CONTROL MODULE ABOVE PARKING BRAKE PEDAL BEHIND DRIVERS SIDE OF DASH
Trunk Trigger GRAY (-) AT BODY CONTROL MODULE ABOVE PARKING BRAKE PEDAL BEHIND DRIVERS SIDE OF DASH
Hood Trigger BLUE (-) AT BODY CONTROL MODULE ABOVE PARKING BRAKE PEDAL BEHIND DRIVERS SIDE OF DASH
Alarm Disarm RED (-) AT BODY CONTROL MODULE ABOVE PARKING BRAKE PEDAL BEHIND DRIVERS SIDE OF DASH
Parking Lights YELLOW (-) AT BODY CONTROL MODULE ABOVE PARKING BRAKE PEDAL BEHIND DRIVERS SIDE OF DASH
Remote Start
Accessory 1 BLUE (+) IGNITION SWITCH HARNESS
Anti-Theft Type UNIVERSAL IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense RED (-) AT BODY CONTROL MODULE ABOVE PARKING BRAKE PEDAL BEHIND DRIVERS SIDE OF DASH
Neutral Safety BLACK/ WHITE (+) AT ECM MODULE ON DRIVERS SIDE SHOCK TOWER NEAR RIGHT SIDE OF ENGINE
Tachometer YELLOW (AC) IN HARNESS AT OBD-II CONNECTOR UNDER DRIVERS SIDE OF DASH
   CAN ALSO BE FOUND AT ECM MODULE ON DRIVERS SIDE SHOCK TOWER NEAR RIGHT SIDE OF ENGINE AS BLACK/ ORANGE - PIN #A26.
Crankshaft Sensor GREEN OR RED (AC) AT ECM MODULE ON DRIVERS SIDE SHOCK TOWER NEAR RIGHT SIDE OF ENGINE
Camshaft Sensor PINK OR BLUE (AC) AT ECM MODULE ON DRIVERS SIDE SHOCK TOWER NEAR RIGHT SIDE OF ENGINE
Speed Sense LIGHT GREEN (AC) IN HARNESS AT BACK OF GAUGE CLUSTER
   CAN ALSO BE FOUND AT ECM MODULE ON DRIVERS SIDE SHOCK TOWER NEAR RIGHT SIDE OF ENGINE - PIN #A15.
Brake Lights BLUE (+) AT SWITCH ABOVE PEDAL
Reverse Lights RED / BLACK (+) AT BODY CONTROL MODULE ABOVE PARKING BRAKE PEDAL BEHIND DRIVERS SIDE OF DASH
Horn GREEN / WHITE (-) AT BODY CONTROL MODULE ABOVE PARKING BRAKE PEDAL BEHIND DRIVERS SIDE OF DASH
IMO GREEN (DATA) AT ECM MODULE ON DRIVERS SIDE SHOCK TOWER NEAR RIGHT SIDE OF ENGINE
IMI VIOLET (DATA) AT ECM MODULE ON DRIVERS SIDE SHOCK TOWER NEAR RIGHT SIDE OF ENGINE
Alarm Indicator BLACK (+) AT BODY CONTROL MODULE ABOVE PARKING BRAKE PEDAL BEHIND DRIVERS SIDE OF DASH
Heated Driver Seat BLACK (+) IN HARNESS AT SEAT HEATER SWITCH
Heated Passngr Seat GREEN (+) IN HARNESS AT SEAT HEATER SWITCH
Doorlocks/Windows
Power Unlock GREEN (-) AT BODY CONTROL MODULE ABOVE PARKING BRAKE PEDAL BEHIND DRIVERS SIDE OF DASH
PowerLock BLACK (-) AT BODY CONTROL MODULE ABOVE PARKING BRAKE PEDAL BEHIND DRIVERS SIDE OF DASH
Driver Mtr Unlock RED (REV) AT MOTOR IN DOOR
Driver Mtr Lock BLACK (REV) AT MOTOR IN DOOR
Pas Mtr Unlock LIGHT BLUE (REV) AT MOTOR IN DOOR
Pas Mtr Lock PINK (REV) AT MOTOR IN DOOR
LF Window Up VIOLET (+) AT MOTOR ASSEMBLY IN DOOR
LF Window Dn PINK (+) AT MOTOR ASSEMBLY IN DOOR
RF Window Up VIOLET (+) AT MOTOR ASSEMBLY IN DOOR
RF Window Dn GREEN (+) AT MOTOR ASSEMBLY IN DOOR
LR Window Up RED (+) AT MOTOR ASSEMBLY IN DOOR
LR Window Dn WHITE (+) AT MOTOR ASSEMBLY IN DOOR
RR Window Up RED (+) AT MOTOR ASSEMBLY IN DOOR
RR Window Dn GREEN (+) AT MOTOR ASSEMBLY IN DOOR
Sunroof Open GREEN (+) IN HARNESS AT SUNROOF SWITCH
Sunroof Close VIOLET (+) IN HARNESS AT SUNROOF SWITCH
Note: Code Systems makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Code Systems disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
mangolango
Member - Posts: 11
Posted: December 30, 2010 at 1:46 PM / IP Logged
Can anyone tell me the 3.5L SE alarm wiring? I am looking a trunk release wire! many thanks
Mike M2
Platinum - Posts: 2,652
Posted: December 30, 2010 at 8:50 PM / IP Logged
do you mean the power hatch wire? It is red, ECU, white 28 pin plug, pin 8.
Mike M2
Tech Manager
CS Dealer Services
tedmond
Gold - Posts: 4,610
Posted: December 31, 2010 at 9:56 AM / IP Logged
i did an alarm/start compustar pro yday for my aunt, and let me tell you, more than half the wires listed are wrong.
i cross referenced from astrochart, audiovox, omega, and autostart. The only correct wiring diagram was Fortin, and they have such limited info (lock/unlock/start related wires/trunk)
no door trigger info. I couldnt fine the wires for the life of me. I ended up wiring up the start portion only.
Ted
Compustar Expert
tedmond
Gold - Posts: 4,610
Posted: December 31, 2010 at 9:57 AM / IP Logged
trunk release was BLUE (-) in a white plug for me.
Ted
Compustar Expert
mangolango
Member - Posts: 11
Posted: January 02, 2011 at 4:46 PM / IP Logged
Thanks so much I work in dealer. I purchase a Prestige alarm remote start from the guy that usually install system for our dealer but I think he is limited in information. He did my alarm but the remote trunk only work in the first couple minute and then it won't open the trunk at all. I can hear the clicking sound in the relay but cannot open the hatch. And we found out the factory alarm is way more user friendly than aftermarket. e.g it can open the side door or hatch without press unlock button. but I need a long range remote start so I go for aftermarket. Still love the factory remote. Thanks for all. by the way where is the ECU locate with red wire? Happy New Year
tedmond
Gold - Posts: 4,610
Posted: January 02, 2011 at 11:05 PM / IP Logged
ecm is left of the steering collum.
in order for the trunk to work, you need to double pulse the unlock wire to unlock ALL doors then it will open. As far as sliding doors, you can go to the contact switch itself and wire a relay in. This is what i did for my aunt.
I ended up finishing the entire install with trunk and door triggers. The hood pin must be run, i tripped check and couldnt find the wire.
Ted
Compustar Expert
80085
Copper - Posts: 93
Posted: January 10, 2011 at 2:19 AM / IP Logged
Anyone else who worked on a 2011 Sienna, are 3 of the wires in the ignition connector a noticeably smaller gauge?
chev104275
Gold - Posts: 1,427
Posted: January 10, 2011 at 5:01 AM / IP Logged
I have not done a new sienna but I've done a couple new toyotas and they have had small gauge wires at the ing switch.
Page of 3
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
