4113 and dlpk on 08 impala
Platinum - Posts: 7,828
Posted: December 22, 2014 at 3:30 PM / IP Logged Link to Post Post Reply Quote kreg357
No.  It should be +12V and a Light Blue wire.  Here is the info from Bulldog Security :
BRAKE LT. BLUE (+) IN DRIVER KICK or BCM, BROWN PLUG, PIN 5
chiefdone1
Member - Posts: 25
Posted: December 22, 2014 at 9:06 PM / IP Logged Link to Post Post Reply Quote chiefdone1
I completed installation but have problems.
One, when I plugged in DLPK CONN 1, I did not get the flash on the unit that it said I should while holding down button on unit.
Went ahead and connected the other plugs on DLPK and all plugs on 4113.
When I tried to remote start, lights came on, heard 4 clicks and then shut off with message on car to Service Theft Deterrent System. Tried sequence again and then it "freezes" until I remove ground on H3/1. Then the parking lights stay on until I open drivers door. Car still starts with key and all acts normal.
Left menu 1 as it came. Changed menu 2 feature 1 to off. Changed menu 2 feature 4 to 1 second. All others remain as it came.
I know I must have several issues but am thinking the theft deterrent message has something to do with the DLPK not flashing or programming correctly.
Where should I start? Read out diagnostics and got 7 flashes yet if I leave toggle off, it won't even try to star remotely. When I turn it on, it tries.
Thanks for any guidance.
Chiefdone
Posted: December 22, 2014 at 9:41 PM / IP Logged Link to Post Post Reply Quote kreg357
Here is what your wiring should look like :
Avital 4113
H1/1  LIGHT GREEN/ BLACK  FACTORY ALARM DISARM     Not Used
H1/2  GREEN / WHITE  FACTORY REARM     Not Used
H1/3  YELLOW  (+) IGNITION OUT (TO ALARM)        Not Used
H1/4  WHITE/ BLUE  (-) ACTIVATION INPUT Not Used
H1/5  ORANGE  (-) GROUND WHEN LOCKED           Not Used
H1/6  BROWN  (-) HORN OUTPUT    tan (-)  @ BCM under driver dash, brown plug, pin 18
H1/7  RED / WHITE  (-) TRUNK RELEASE OUTPUT    Not Used
H1/8  BLACK  GROUND        Chassis Ground
H1/9  WHITE  (+/-) LIGHT FLASH   *** Set to (-)          BROWN / white (-)   @ BCM under driver dash, white plug, pin 8
H2/1  BLACK/ WHITE  (-) NEUTRAL SAFETY SWITCH INPUT        Chassis Ground
H2/2  VIOLET/WHITE  TACHOMETER INPUT WIRE          DLPK Violet/White
H2/3  BROWN  (+) BRAKE SWITCH SHUTDOWN WIRE    lt. blue (+)  BCM under driver dash, brown plug, pin 5
H2/4  GRAY  (-) HOOD PINSWITCH SHUTDOWN WIRE    Hood Pin or DLPK Grey if Impala has Factory Hood Pin
H2/5  BLUE/WHITE  (-) 200mA 2ND STATUS/REAR DEFOG          Not Used
4-pin satellite harness diagram
1  BLUE  STATUS OUTPUT   DLPK Blue/White
2  ORANGE  (-) ACCESSORY OUTPUT       Not Used
3  PURPLE  (-) STARTER OUTPUT Not Used
4  PINK  (-) IGNITION OUTPUT        Not Used
Heavy gauge relay wiring diagram
1  PINK  (+) (30 AMP) OUTPUT TO IGNITION CIRCUIT           Pink @ Ignition Plug
2  PURPLE  (+) (30 AMP) OUTPUT TO STARTER CIRCUIT     Not Used
3  ORANGE  (+) (30 AMP) OUTPUT TO ACCESSORY CIRCUIT          Brown @ Ignition Plug
4  RED  (+) (30A) HIGH CURRENT 12 INPUT RED / white #1 @ BCM under driver dash, black plug, pin 1
5  PINK/WHITE  (+) PROGRAMMABLE OUTPUT        Not Used
6  RED  (+) (30A) HIGH CURRENT 12V INPUT   RED / white #2 @ BCM under driver dash, black plug, pin 2
Door lock harness, 3-pin connector
1  BLUE  (-) UNLOCK OUTPUT           DLPK Blue
2  EMPTY  NOT USED
3  GREEN  (-) LOCK OUTPUT   Not Used
DLPK  ( Follow diagram )
Violet/White     to 4113 Violet/White Tach
Blue/White       to 4113 Blue Status Output
Grey     to 4113 H2/4 Grey ( if Impala equipped with hood pin )
Blue      to 4113 Blue Unlock
Plus these 5 wires to Impala as per diagram
Yellow
WHITE/ Black
Pink
Light Green
Brown
chiefdone1
Member - Posts: 25
Posted: December 23, 2014 at 11:32 AM / IP Logged Link to Post Post Reply Quote chiefdone1
Rechecked all wiring as per your last post. The only thing I didn't hook up was hood trigger. As I understand it, this input is not active unless it sees a ground when hood opened. Other than the safety aspect of this, but does the input require to be hooked up?
Still will not remote start. Get message to "Service Theft Deterrent System".
Have never seen flash on DLPK to indicate it is active. Is it possibly bad? Any other thoughts?
I really appreciate all your input on this.
Chiefdone
Posted: December 23, 2014 at 12:15 PM / IP Logged Link to Post Post Reply Quote kreg357
Did the DLPK program properly as per the install guide?  ( page 2 of the install guide )
chiefdone1
Member - Posts: 25
Posted: December 23, 2014 at 12:55 PM / IP Logged Link to Post Post Reply Quote chiefdone1
No, it did not. I tried several times but near saw the confirming flash on the DLPK.
Chiefdone
Posted: December 23, 2014 at 1:44 PM / IP Logged Link to Post Post Reply Quote kreg357
Sounds like a bypass module issue.
chiefdone1
Member - Posts: 25
Posted: December 23, 2014 at 4:22 PM / IP Logged Link to Post Post Reply Quote chiefdone1
Thank you kreg357 for all your help. I believe you have helped me greatly but unfortunately, system doesn't work.
I have today ask for a replacement DLPK from my supplier. I explained all I had done and that I do believe the DLPK is the problem.
Chiefdone
chiefdone1
Member - Posts: 25
Posted: December 23, 2014 at 7:56 PM / IP Logged Link to Post Post Reply Quote chiefdone1
Maybe you can help me with this question. My supplier has agreed to exchange my DLPK. However, I have to return it before they will send a new one. Since I have wired everything (soldered and taped, when I remove the DLPK, will I have to splice any wires together to let the car run normally? I am thinking particularly of the brown wire a cut on the transponder.
Chiefdone
Posted: December 23, 2014 at 8:49 PM / IP Logged Link to Post Post Reply Quote kreg357
Will he let you keep the harnesses and just return the module?  He could just send you a replacement module without the harnesses, they won't be of much value after they were cut & soldered.  What a pain to remove all the harnesses.  But yes, you must temporarily reconnect that cut brown wire.  Think I would leave about an inch or two of DLPK wire at each connection and splice into that when the new one arrives.  You could just strip and twist the two sides of the Brown wire connection and insulate with black tape until the replacement arrives to drive the car.
Page of 5
