Intellistart 4 RPM Programming
punker
Member - Posts: 10
Posted: January 07, 2016 at 11:20 AM / IP Logged Link to Post Post Reply Quote punker
Hi,
I have an AvantGuard 5.5 installed on my 1994 Peugeot 205 diesel and I'm adding an Intellistart unit to it. I believe the wiring is ok, but I'm stuggling to program the RPM for the remote start.
There aren't many sensors on a XUD7 n/a diesel engine, so I've taken a supply from one alternator winding (internally). I get about 9v AC at idle. Should this be ok?
I initially tried manually programming, but my PlainView switch was playing up (turned out to me a dodgy connector). So I then tried the CliffNet Wizard, and always got 'nocode' every time I tried to learn the RPM.
So then I sorted the valet switch and tried manual programming again. Sometimes I get one chirp, sometimes two, but it never seems to store it.
Upon doing some research AFTER I tried programming the RPM with the Wizard, it seems I may have messed things up.
So basically, is there a way to 'reset' the Intellistart to accept the RPM being programmed manually, or do I have to get a new unit?
Posted: January 07, 2016 at 1:04 PM / IP Logged Link to Post Post Reply Quote howie ll
Get a 465 tach generator from the importers and a new switch.
You're going to damage the alternator and the Whizz doesn't work on G5 product, manual initialisation is the only way to go.
punker
Member - Posts: 10
Posted: January 07, 2016 at 1:17 PM / IP Logged Link to Post Post Reply Quote punker
Thanks for your reply Howie. Ok, I'll get them ordered.
Do you think my Intellistart will be ok? I mean, will it program ok manually after I've already used the Wizard with it? Assuming I get a decent tach signal sorted that is :)
Posted: January 07, 2016 at 1:23 PM / IP Logged Link to Post Post Reply Quote howie ll
Yes, never really used the Whiz on G5. The car worries me more, does it start when the glow plug light goes out without having to pump the accelerator?
punker
Member - Posts: 10
Posted: January 07, 2016 at 1:28 PM / IP Logged Link to Post Post Reply Quote punker
OK cool :)
Is 9v a little too much for the I/S tach wire?
Yeah, it starts very well, as long as the glowplug light is out it will always fire literally within half a second, no pedal pumping at all :)
Can you recommend somewhere in the UK to get the tach generator and switch?
Posted: January 07, 2016 at 1:42 PM / IP Logged Link to Post Post Reply Quote howie ll
Actually the part is 455t tach generator.
That and switch Car Audio Security, the importer.
punker
Member - Posts: 10
Posted: January 07, 2016 at 1:46 PM / IP Logged Link to Post Post Reply Quote punker
Thanks Howie :) Yeah, just been searching and 465 seems to be something to do with fobs. And 455 is something Jeep related Intellistart 4 RPM Programming -- posted image.
Could the tach generator be 454t?
punker
Member - Posts: 10
Posted: January 07, 2016 at 1:50 PM / IP Logged Link to Post Post Reply Quote punker
http://caraudiosecurity.com/454t-alternator-rpm-detector-tach-signal-generator
Is this the one?
Posted: January 07, 2016 at 1:54 PM / IP Logged Link to Post Post Reply Quote howie ll
Yes and they will also have the switch.
punker
Member - Posts: 10
Posted: January 07, 2016 at 1:55 PM / IP Logged Link to Post Post Reply Quote punker
Thanks for your help :)
Sunday, June 2, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
