astra 4000rs
f29966
Member - Posts: 36
Posted: June 28, 2010 at 11:36 PM / IP Logged
i'm installing the Astra 4000rs alarm & remote starter system . my car is a Honda Accord 95 , i try to do remote start after hookup all the wire ( no tach wire connect yet ) , however the car start with out the tach wire , if i using the remote start with out the tach signal wire , is it damage to the car ? or it good to use it like that .
mikvot
Gold - Posts: 1,043
Posted: June 29, 2010 at 7:03 PM / IP Logged
No damage will occur. You can run it with or without the tach. You might run across problems with remote starting during the winter, but Scytek stuff is generally reliable in tachless mode.
f29966
Member - Posts: 36
Posted: June 30, 2010 at 8:50 AM / IP Logged
i'm new to install remote start , i don't understand about the tachless mod , can you explain about it ? thank you for your help
brent w
Member - Posts: 26
Posted: July 01, 2010 at 2:41 PM / IP Logged
Ok so tachless mode watches the voltage of your car.  You hit the remote start, your voltage drops while the starter is cranking, then when the car starts and the alternator is charging the car's electrical system the voltage picks back up.  So basically, it sees a voltage drop while cranking, then once the car starts and the voltage picks back up, it stops cranking...but it sees all this really fast, so no overcranking issues.
When i install a RS, i try it tachless and 95% of the time it works.  If it doesnt work, i get a tach source.
f29966
Member - Posts: 36
Posted: July 03, 2010 at 11:27 PM / IP Logged
i'm understand now , thanks alot
boxhead78
Copper - Posts: 84
Posted: July 05, 2010 at 9:49 AM / IP Logged
1995 Honda Accord Alarm, Remote Starter, Keyless Entry Wiring Information
Constant 12V+ White  Ignition Switch Harness or Fuse Panel
Starter BLACK/ White  Ignition Switch Harness
Ignition BLACK / YELLOW  Ignition Switch Harness
Accessory Yellow  Ignition Switch Harness
Tach Blue  Distributor
Brake Switch GREEN / WHITE  Brake Switch
Trunk Pin ORANGE / Silver (-)  Right of Column Gray Connector
Parking Lights RED / Black  Fuse Panel Blue Connector
Head Lamp Blue  Left of Column Blue Connector
Hood Pin n/a
Door Trigger BLACK/ White (-)  Right of Column Gray Connector
Door Lock BLACK/ White (-)  Gray Connector above Fuse Panel TapeD to Harness
Door Unlock Orange (-)
Horn Wire GREEN/ Blue (-)  Left of Column Gray Connector
boxead78
