1997 Dodge Viper Factory Alarm Location
mo12v
Posted: October 24, 2004 at 4:35 PM / IP Logged
This is what I have:
Constant 12 voltsRED & PINK/BLACKIGNITION SWITCH HARNESS
Ignition 12 voltsD BLUEIGNITION SWITCH HARNESS
StarterYELLOWIGNITION SWITCH HARNESS
Dome LightYELLOW (-)AT FUSE BLOCK BEHIND DRIVER DASH
Trunk Pin SwitchGRAY/BLACK (-)AT LIGHT IN TRUNK
Parking LampTAN (+)AT HEADLIGHT SWITCH
Power LockN/A
Power UnlockN/A
Accessories
Window UpD\ L BLUE P\ BROWN @ MAIN SWITCH
Window DownR/ WHITE S/ VIOLET
Ign Key Warn
Trunk Release
OEM HornBLACK/ RED (-)STEERING COLUMN HARNESS
HeadlightsL GREEN/ RED (+)AT HEADLIGHT SWITCH
OEM Alarm ArmN/A
OEM Alarm DisarmN/A
 Reversal Rest At Ground Power Window Circuit
Remote Start
Tach SignalBLACK/ GRAYAT LEFT IGNITION COIL PACK
Ignition #2BLACK/ ORANGEIGNITION SWITCH HARNESS
Ignition #3N/A
AccessoryBLACK/ WHITEIGNITION SWITCH HARNESS
Neutral SafetyNOT GROUNDING TYPE -OEM SWITCH OPENS STARTER CIRCUIT
Brake LightVIOLET/BLACK (+)AT SWITCH ABOVE BRAKE PEDAL
Reverse LightWHITE (+)AT SWITCH ON TRANSAXLE
Rear Window Defrost
MO
draasch
Gold - Posts: 2,172
Posted: October 24, 2004 at 5:41 PM / IP Logged
i also have that info mo12v, however this car doesnt have "door locks" as we would think......when you "lock" the doors, you just disable the door release wire that allows the door to pop open.....
thanks for the info...
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
mo12v
Posted: October 24, 2004 at 5:48 PM / IP Logged
10-4.........Didn't mean to throw a monkey wrench:
The last one I worked on, I used the Factory Keyless for RS & didn't recall an Alarm on it.
But I know the RKE was next to steering column
MO
