alarm/remote start, 1997 acura 2.2cl
another-kelly
Silver - Posts: 618
Posted: January 25, 2006 at 2:05 PM / IP Logged
Parking Brake GREEN/ red  -  parking brake switch
NSS would be the small gauge neutral safety switch wire on the clifford. this way, the vehicle will only start when the e-brake is on. you'll have to test the clutch wire. most likely it is a neg. trigger in which case:
85 - clutch (neg)
86 - +12v
87 - +12v
30 - to brown brake shutdown on clifford
another-kelly
Silver - Posts: 618
Posted: January 25, 2006 at 2:07 PM / IP Logged
another thing. i advise against t-taps on the ignition harness. if you use the wrong ones, they can melt due to the amount of current passing through. not all pro's use them. i don't.
bigpimpin18
Member - Posts: 29
Posted: January 30, 2006 at 5:23 PM / IP Logged
well today I did the remote start part of my alarm and I got the wires ran. Now it's just got the little gliches. First of all, I went to go remote start it and it fired up than 5 seconds after that it died. This is on a 1997 Acura 2.2CL. What do I have to do to get this thing going??
Page of 3
Sunday, July 13, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
