domelight and reverse lights h1/4
jcs091570
Copper - Posts: 155
Posted: April 30, 2010 at 3:22 AM / IP Logged
I am interested in adding a little feature to my dome light supervision function. I have my DEI H1/4 wire pushing a relay and connected to my negative dome circuit. I would like to tap into the H1/4 wire to also illuminate my reverse lights at the same time. But not when I open the door in general. Only on disarming and when removing key from ignition. I know I will need another relay but unsure of the connections. All the lights are LEDs and will draw minimal current. Any input would be appreciated thanks.
juavos00
Copper - Posts: 66
Posted: May 05, 2010 at 10:05 PM / IP Logged
that would be sweet. I hope someone can answer your question as I may do that to mine aswell.. :)
jcs091570
Copper - Posts: 155
Posted: May 05, 2010 at 10:16 PM / IP Logged
Well I actually figured it out. If you are interested..let me know. I had to use a separate relay.
juavos00
Copper - Posts: 66
Posted: May 05, 2010 at 10:30 PM / IP Logged
definitely.. Please post it up here, and I may give it a shot. Thanks
jcs091570
Copper - Posts: 155
Posted: May 05, 2010 at 10:39 PM / IP Logged
Ok here it is, Pin 86 and Pin 30 go to fused constant 12v... Pin 85 goes to dome light output of alarm (Blk/Wht) and Pin 87 taps into 12v reverse light wire. I placed a 1 amp diode on the 87 wire with band facing towards reverse light circuit as a safety precaution. The reasoning behind this is when I put my car in reverse and the rev light wire shows 12volts, I don't want the current to possible damage the relay circuit. Current only allowed in one direction on that wire.
juavos00
Copper - Posts: 66
Posted: May 05, 2010 at 10:44 PM / IP Logged
cool I may get around to trying this out, if I can get my keyless entry working in the first place.. lol
Anyway I know you might not know, but I want to ask anyway. Should I use a relay on the original domelight supervision output wire to the factory wiring? My DEI system shows that the output wire can drive circuits up to 30 amperes. If not, I found a website that shows me how to wire up a relay to protect the DEI brain.
jcs091570
Copper - Posts: 155
Posted: May 05, 2010 at 10:46 PM / IP Logged
Oh by the way.. I used a standard Bosch 30/40amp 12vdc relay. Also, Pin 87a will supply 12volts when the relay is off. But when energized, it turns off. This can be handy to supply current to a device in your vehicle you wish to use when the alarm system is armed. I plan to hook it to my interior blue lights and Led lights under my vehicle to turn on when arming the car, and off when disarming. I will attach it to a switch to control when I want this function. Just watch amp draw on any circuit or relay.
jcs091570
Copper - Posts: 155
Posted: May 05, 2010 at 10:48 PM / IP Logged
what model DEI alarm do you have? Some have the onboard relay and some don't.
juavos00
Copper - Posts: 66
Posted: May 05, 2010 at 10:51 PM / IP Logged
Avital 2101L
Its made by DEI
Also do I have to use the 87A on that circuit, or can I just leave it out?
jcs091570
Copper - Posts: 155
Posted: May 05, 2010 at 11:00 PM / IP Logged
No you won't need that. Is your dome light (door trigger) circuit negative or positive?
Page of 4
Tuesday, November 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
