bsbdoa, thanks for the info. I have not hooked up anything to automatically lock the doors since I found that it is a programming option. I disconnected the hood input that was grounded. Current status is as follows:
Primary harness (H1), 12-pin connector
H1/1 RED / WHITE (-) 200mA TRUNK RELEASE OUTPUT
not connected
H1/2 RED (+)12v CONSTANT INPUT
Connected to 12v in steering column
H1/3 BROWN (+) SIREN OUTPUT
connected to siren
H1/4 WHITE/ BROWN LIGHT FLASH -ISOLATION WIRE - PIN 87a of onboard relay
not connected
H1/5 BLACK (-) CHASSIS GROUND
connected to ground
H1/6 VIOLET (+) DOOR TRIGGER INPUT
connected to door "open" wire
H1/7 BLUE (-) TRUNK PIN/ INSTANT TRIGGER INPUT
not connected
H1/8 GREEN (-) DOOR TRIGGER INPUT connected to ground
Have not removed this yet. Next step.
H1/9 BLACK/ WHITE (-) 200mA DOME LIGHT OUTPUT
not connected
H1/10 WHITE/ BLUE (-) REMOTE START/ TURBO TIMER ACTIVATION INPUT
not connected
H1/11 WHITE PARKING LIGHT OUTPUT
connected to parking lights at the headlamp switch
H1/12 ORANGE (-) 500mA GROUND WHEN ARMED OUTPUT
not connected
Auxiliary harness (H2), 8-pin connector
not connected AND not plugged into brain
H2/1 LIGHT GREEN/ BLACK (-) 200mA FACTORY ALARM DISARM OUTPUT
H2/2 LIGHT GREEN / WHITE (-) 200mA FACTORY ALARM ARM OUTPUT
H2/3 WHITE/ VIOLET (-) 200mA AUX 1 OUTPUT
H2/4 VIOLET/BLACK (-) 200mA AUX 2 OUTPUT
H2/5 WHITE/ BLACK (-) 200mA AUX 3 OUTPUT
H2/6 LIGHT BLUE (-) 200mA 2ND UNLOCK OUTPUT
H2/7 GRAY/BLACK (-) DIESEL WAIT TO START INPUT
H2/8 BROWN / BLACK (-) 200mA HORN HONK OUTPUT
H3 Door lock harness, 3-pin connector
1 BLUE (+) LOCK (-) UNLOCK OUTPUT
connected to power door locks relay and working
2 EMPTY NOT USED
3 GREEN (-) LOCK (+) UNLOCK OUTPUT
There are three harness connections relative to remote start function, including the heavy gauge and input and output harnesses.
Heavy gauge remote start, (H3)
10-pin connector
1 PINK (+) IGNITION 1 INPUT/OUTPUT
connected to 12v when key is in the RUN position.
2 RED / WHITE (30A) FUSED IGNITION 2 / FLEX RELAY INPUT 87
not connected
3 ORANGE ACCESSORY OUTPUT
Connected to 12Volt accessory
4 VIOLET (+) STARTER OUTPUT (CAR SIDE OF THE STARTER KILL WIRE)
connected to starter side of the start wire
5 GREEN (+) STARTER INPUT (KEY SIDE OF THE STARTER KILL WIRE)
connected to the key side of the start wire.
6 RED (+) FUSED (30A) IGNITION 1 INPUT
connected to 12Volt constant
7 PINK/WHITE (+) IGNITION 2 / FLEX RELAY OUTPUT
not connected
8 PINK/BLACK FLEX RELAY INPUT 87A key side (if required) of FLEX RELAY
not connected
9 RED / BLACK FUSED (30A) ACCESSORY/STARTER INPUT
connected to 12v constant
10 N/C N/C
Remote start input, 5-pin connector
1 BLACK/ WHITE (-) NEUTRAL SAFETY SWITCH INPUT
connected to ground
2 VIOLET/WHITE TACHOMETER INPUT WIRE
connected to BLACK / YELLOW wire going to the tachometer. Verified by running and revving the engine while connected to a voltmeter.
3 BROWN (+) BRAKE SHUTDOWN WIRE
connected to brake switch from the pedal
4 GRAY N/O or N/C (-) HOOD PIN SWITCH INPUT, ZONE 6
disconnected from ground
5 BLUE/WHITE (-) 200 mA 2ND STATUS/REAR DEFOGGER
not connected
Remote start auxiliary output, 5-pin
1 PINK/WHITE (-) 200mA FLEX RELAY CONTROL OUTPUT
2 ORANGE (-) 200mA ACCESSORY OUTPUT
3 VIOLET (-) 200mA STARTER OUTPUT
4 PINK (-) 200mA IGNITION 1 OUTPUT planning to connect to LOCK relay
5 BLUE (-) 200mA STATUS OUTPUT
