switch with alarm accessory output
killerbean24
Member - Posts: 8
Posted: September 27, 2010 at 5:40 PM / IP Logged
How do I wire a switch inside the cab to control the same output as one of my alarm accessory output wires?
Example: My HID off-road lights are hooked to an accessory wire from my alarm, which allows the HID's to be turned off and on via the alarm remote. How do I also wire them up so also be controlled via a switch inside the cab?
Posted: September 28, 2010 at 1:10 AM / IP Logged
2 terminal switch, one side to ground other side to aux, BUT, at the aux, before you join wire off 2 diodes, 1N4004 in a Y shape, one to the HID relay, the other to your switch, bands towards the alarm/RS.
This will prevent a feedback possibly damaging your alarm.
killerbean24
Member - Posts: 8
Posted: September 28, 2010 at 11:26 AM / IP Logged
So Like this?? Pin 30 doesn't look right to me.
switch with alarm accessory output -- posted image.
dualsport
Silver - Posts: 983
Posted: October 03, 2010 at 9:17 PM / IP Logged
You show pin 30 permanently connected to ground, so your switches won't do anything. Just remove that connection to ground and it should be okay.
killerbean24
Member - Posts: 8
Posted: October 04, 2010 at 12:58 PM / IP Logged
Pin 30 has to be either ground or power, right?
My diagram is based off this diagram on the relay's page...
2006 Dodge Ram 2500 * Superchips 3805 Tuner * Clarion NX500 * Kicker ZR600 * Kicker Solo-Baric 12 in custom center console
2003 BMW Z3 * Stock.. for now!!
Posted: October 04, 2010 at 1:35 PM / IP Logged
This is all you need, if you use a latching circuit, how will you turn it off?
Alternatively leave the alarm's output as momentary, keep the momentary switch and feed a 528t or something similar, you7 can then set the time from 1 sec to 5 minutes.
killerbean24
Member - Posts: 8
Posted: October 04, 2010 at 2:03 PM / IP Logged
This doesn't work for my application, because once you send the negative pulse, the relay will only activate for a short period of time. I need the pulse to activate a latched circuit until another negative pulse is sent. My diagram is correct, except I can't figure out if pin 30 on the third relay is negative or positive. It appears to me that 30 needs to be a negative input to energize that relay. I guess I will just wire it up and test it real time.
Posted: October 04, 2010 at 2:16 PM / IP Logged
Forget all those relays and you can set the timing, use a 528t with a momentary switch. The 528t is wired as a normal relay, your latching circuit wont turn off.
30 SHOULD be the pos output from the relay to the lights. Basic amateur problem, you're over complicating things and getting in over your head.
killerbean24
Member - Posts: 8
Posted: October 04, 2010 at 2:45 PM / IP Logged
Nevermind... Rookie mistake! I just wasn't attention to notice that 30 IS the negative trigger, and the others are just ground all the time. Woops. Here is the circuit...
P.S. I am sure the 528t would do something similar, but for me, relays are much easier and cheaper to work with. $1.29/relay vs. $20 for the 528t.
Posted: October 04, 2010 at 4:18 PM / IP Logged
OK. That's a good price on those relays, I thought they were cheaper here, I pay equivalent to $1.20
Tuesday, February 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
