2011 2012 hyundai sonata gls wiring
frostsonta
Member - Posts: 7
Posted: October 25, 2012 at 4:50 PM / IP Logged
Hi guys, great forum! I have been searching all over for the wiring diagram that will point me to the wires needed to install a comfort option in my remote starter. The comfrot option has the window rollup feature but I'd like to know where to find the wires under the dash.
lurch228
Silver - Posts: 1,338
Posted: October 25, 2012 at 5:31 PM / IP Logged
readyremote.com
bulldogsecurity.com
Platinum - Posts: 7,828
Posted: October 25, 2012 at 5:53 PM / IP Logged
Didn't see the power window info at either Bulldog Security or ReadyRemote but Audiovox has it.  Here is a
link to their WEB site :  http://techservices.audiovox.com/AccessRequest.aspx   Sign-up is free!!!  2011 2012 hyundai sonata gls wiring -- posted image.
frostsonta
Member - Posts: 7
Posted: October 25, 2012 at 5:56 PM / IP Logged
Awesome! Checking all links now! Thanks guys. Let you know how it turns out. Will definitely post a writeup after i get all my info going.
Posted: October 25, 2012 at 6:01 PM / IP Logged
If you haven't done the remote starter portion yet there is a Pictorial on a basic system, just uploaded today.
https://www.the12volt.com/installbay/forum_posts.asp~TID~132478~PN~1
frostsonta
Member - Posts: 7
Posted: October 25, 2012 at 7:30 PM / IP Logged
Thanks kreg357. The audiovox site pointed me to the right place. I was hoping I could get to the wires without pulling the master control power switch open but ah well. No under dash love for me there.....thought I assume they MUST go there at some point...hmm
Posted: October 25, 2012 at 7:46 PM / IP Logged
Only the drivers window has to be connected at the switch.  The other three doors' window wires are in the DPK.   Some more info from another source :
Left Front Window (Up/Down)      brown - gray (w/o safety power window)      power window main switch, white 16 pin plug, pins 9 and 10
Right Front Window (Up/Down)   white - brown               driver kick, door harness
Left Rear Window (Up/Down)      pink - gray        driver kick, door harness
Right Rear Window (Up/Down)   yellow - green              driver kick, door harness
Posted: October 26, 2012 at 4:06 AM / IP Logged
Except if you're using say a 530t, it's better to go to the window motor wires in each door then you'll have one touch up down at all switches.
Otherwise for simply window close use Kregg's last post as your info.
frostsonta
Member - Posts: 7
Posted: November 13, 2012 at 2:02 PM / IP Logged
Sweet. Thanks kreg357. I'm actually in my final stages of my remote start install and came online scratching my head to search the interwebs.
For some odd reason the darn remote isnt pulsing the power lock wire in my Sonata. Sure, remote stat works PERFECTLY if i pulse the door locks from the door lock switch but from the remote....nada. I've looked at all the great writeups on here regarding the diagram and even checked the audiovox website etc....they all point to the same wire. Oh, did I mention its cold outside? :)
frostsonta
Member - Posts: 7
Posted: November 13, 2012 at 2:05 PM / IP Logged
Kreg, just realized that you were the writer of the article, silly me. I was gonna do a writeup before I found your own great article...good job! One question, how on earth did you get the remote to work effectively sending the pulses to the lock(-) wire?
