2015 Honda Pilot EX L, Viper 4606 Install
mcgrathe
Member - Posts: 15
Posted: March 26, 2019 at 10:30 AM / IP Logged Link to Post Post Reply Quote mcgrathe
Can anyone provide the install diagram for a 2015 Honda Pilot installing a Viper 4606? Im using a Idatalink DBI-ALDL for bypass. Its already programmed to HA3. I can wire it. Its the 4606 im not 100% positive on. Especially the 8 pin Heavy connector. Do i hook yellow to the violet? What others do i need of that connector as well? Also what do i need to wire on other connectors to get it to lock unlock etc and run power liftgate. I cant really find a direct wire diagram for it. I read possibly ill need a couple diodes for unlock function? the DBI ALDL im just going to run D2D and wire it to the green connector. Thank you and greatly appreciate time
Eric M
wirewise
Moderator - Posts: 489
Posted: March 26, 2019 at 10:38 AM / IP Logged Link to Post Post Reply Quote wirewise
PILOT      2009-2016
KEY      T-HARNESS      IMMOBILIZER
N/A      N/A      HONDA'S TRANSPONDER ANTI-THEFT SYSTEM, VEHICLES 2015 AND UP REQUIRE A DBALL2 INTERFACE FOR REMOTE STARTING. See NOTE #1
PART      COLOR      LOCATION      DIAGRAM
12 VOLT CONSTANT      WHITE (+)      @ IGNITION SWITCH, (WHITE, 5-Pin Plug) Pin 2
STARTER      YELLOW (+)      @ IGNITION SWITCH, (WHITE, 5-Pin Plug) Pin 1
STARTER 2      N/A
IGNITION 1      PINK (+)      @ IGNITION SWITCH, (WHITE, 5-Pin Plug) Pin 5
IGNITION 2      N/A
IGNITION 3      N/A
ACCESSORY/HEATER BLOWER 1      ORANGE (+)      @ IGNITION SWITCH, (WHITE, 5-Pin Plug) Pin 3
ACCESSORY/HEATER BLOWER 2      RED (+)      @ IGNITION SWITCH, (WHITE, 5-Pin Plug) Pin 4
KEYSENSE      N/A
PARKING LIGHTS ( - )      GRAY (-) (REQUIRES #775 RELAY)      @ HEADLIGHT SWITCH, (BLACK/WHITE, 12-Pin Plug) Pin 11
PARKING LIGHTS ( + )      GRAY (+)      @ DASH FUSE BOX, (LT. GREEN, 42-Pin Plug) Pin 19
POWER LOCK      PINK (TYPE B), See NOTE #2      @ POWER WINDOW Master Switch, (GRAY, 37-Pin Plug) Pin 28
POWER UNLOCK      WHITE (-) and RED (-) TYPE B, (DOUBLE PULSE Required), See NOTE #2      @ POWER WINDOW Master Switch, (GRAY, 37-Pin Plug) Pins 29 and 31
LOCK MOTOR WIRE      LIGHT GREEN (5-wire type)
DOOR TRIGGER      YELLOW (-)      @ DASH FUSE BOX, (LT. GREEN, 42-Pin Plug) Pin 37
DOMELIGHT SUPERVISION      PINK (-)      Above DRIVERS KICK PANEL, (GRAY, 2-Pin Plug) Pin 1
TRUNK RELEASE      ORANGE (-) (Liftgate) NOTE #3 and #4      @ DASH FUSE BOX, (LT. GREEN, 42-Pin Plug) Pin 13
SLIDING POWER DOOR      N/A
HORN      GRAY (-)      @ HORN SWITCH, (WHITE, 20-Pin Plug) Pin 1
TACH      Any wire NOT YELLOW/BLACK (AC)      @ Any FUEL-INJECTOR
WAIT TO START LIGHT      N/A
BRAKE      LIGHT BLUE (+)      @ BRAKE SWITCH or DASH FUSE BOX, (LT. GREEN, 42-Pin Plug) Pin 34
FACTORY ALARM DISARM      DISARMS with UNLOCK
ANTI-THEFT      HONDA'S TRANSPONDER ANTI-THEFT SYSTEM, See NOTE #1      @ IGNITION SWITCH TUMBLER
NOTES
NOTE #1: HONDA'S TRANSPONDER SYSTEM, Requires Bypass Module: (For Remote Starting Only) Part #791 Bypass, (Requires Extra Key) for Operation. (For Remote Starting Only) Part # PK-ALL Bypass. (No Extra Key Required for Operation) 2-KEYS Required to Program Module. (For Remote Starting/Door Locks) Part # DBALL2 (No Extra Key Required for Operation) 1-KEY Required for Programming.
NOTE #2: METER THE DOORLOCK WIRES WHILE TURNING THE KEY IN THE DRIVERS DOOR CYLINDER. WHITE IS THE DRIVER DOOR KEY CYLINDER, WHITE IS THE UNLOCK WIRE AND THE RED IS THE DOOR UNLOCK DETECTION WIRE. USE BOTH WIRES AND DIODE ISOLATE EACH.
NOTE #3: THE HATCH GLASS RELEASE WIRE, IS A PINK (-) LOCATED IN THE DRIVERS KICK PANEL, AT A WHITE, 18-PIN PLUG, PIN 8. TEST THESE WIRES WHILE OPENING THE LIFTGATE/HATCH GLASS FROM THE HANDLE ON THE REAR OF THE VEHICLE.
NOTE #4: ON VEHICLES WITH POWER TAILGATE, THE OPEN/CLOSE WIRES ARE BROWN (SWITCH) AND PURPLE to WHITE (COMMON), ABOVE THE DRIVERS KICK PANEL, IN A WHITE,24-PIN PLUG, PINS 20 AND 9. THESE WIRES SHORT WHEN THE SWITCH IS PRESSED.
https://www.the12volt.com/installbay/forum_posts.asp?tid=135857
~wirewise~
mcgrathe
Member - Posts: 15
Posted: March 26, 2019 at 11:35 AM / IP Logged Link to Post Post Reply Quote mcgrathe
Ok THis connector has park light flash wire. Main Harness, White 6-pin connector
1 RED (+)12V DC CONSTANT INPUT
2 BLACK (-) CHASSIS GROUND
3 BROWN (-) 200mA HORN HONK OUTPUT
4 WHITE/BROWN PARKING LIGHT ISOLATION WIRE - #87a NORMALLY CLOSED of onboard relay
5 WHITE PARKING LIGHT OUTPUT- #30 COMMON of onboard relay
6 ORANGE (-) 500 mA (GWA) GROUND WHEN ARMED OUTPUT
so if i set my viper to flash lights + polarity i just need to tie #5 white wire into this wire(PARKING LIGHTS ( + )      GRAY (+)      @ DASH FUSE BOX, (LT. GREEN, 42-Pin Plug) Pin 19   ) and not need to relay the - wire?
My door lock connector has 3-pin connector
1 BLUE (-) 500mA UNLOCK OUTPUT
2 EMPTY NOT USED
3 GREEN (-) 500mA LOCK OUTPUT
Do i need one or both of those and if so what ones tie into which unlock and sense wire with diode?
Thank you for fast response. I can figure out the rest with that info.
Eric M
Platinum - Posts: 7,828
Posted: March 27, 2019 at 6:26 PM / IP Logged Link to Post Post Reply Quote kreg357
To get a (+) Parking Light Output on that White wire, you must ensure the
Parking Light Fuse/Jumper is set to (+). It is located under the sliding
cover of the controller. The White/Brown wire will not be used for your
application. No relay is needed. The Viper has an internal relay.
If you are using an ADS AL-CA that has been flashed with the DBI DL HA3
firmware and going D2D between the Viper and the ADS AL-CA modules, there
is no need to connect the Vipers Lock and Unlock wires to anything. The
D2D harness handles the Viper to bypass module communications and the
Bypass module to Pilot CAN wire connections handles the rest. Here is a
link to the bypass module install guide ( follow Type 1 diagram ) :
    http://images.idatalink.com/corporate/Content/Manuals/DL-HA3/DBI-AL(DL)-HA3-EN_20170513.pdf
Here is a link to a Pictorial on your Pilot using an ADS AL-CA bypass
module. Your install will be the same except that you are going to
use a (+) Parking Light wire instead of the (-) one used in the photos.
    https://www.the12volt.com/installbay/forum_posts.asp?tid=144741
For the Viper thick Starter harness :
Remote Start, White 8-pin connector
1 RED/BLACK (+) FUSED 12V ACC/STARTER INPUT.................White @ Ignition Switch harness
2 PINK/BLACK (+) FLEX RELAY INPUT #87a................................not used
3 PINK/WHITE (+) IGNITION 2/FLEX RELAY..................................not used ( optional * )
4 RED (+) FUSED 12V IGNITION 1 INPUT.......................................White @ Ignition Switch harness
5 VIOLET (+) STARTER OUTPUT.....................................................Yellow @ Ignition Switch harness
6 ORANGE (+) ACCESSORY OUTPUT.............................................Red @ Ignition Switch harness
7 RED/WHITE (+) FUSED 12V IGNITION 2 / Flex............................White @ Ignition Switch harness
8 PINK (+) IGNITION 1 INPUT/OUTPUT............................................Pink @ Ignition Switch harness
* The Pink/White wire can be used for the Red ACC2 wire if the Viper is Programmed accordingly.
mcgrathe
Member - Posts: 15
Posted: March 27, 2019 at 8:00 PM / IP Logged Link to Post Post Reply Quote mcgrathe
Awesome. Thanks for the info.
I bought a directed t harness for a DS4+ Setup off eBay for like $15 and cut off the ends that connect to DS 4. Let’s me T the ignition and Data connectors so I’ll have minimal wires to tap into. Figured for $15 it will save a bunch of wire time as well as make removal easy if I sell vehicle in future.
So far as the power lift gate goes... It looks as the purple and brown wire short when the button is pressed according to the other post I see
“On models with power tailgate, the open/close are brown (switch) and purple (com), above the driver kick, white 24 pin plug, pins 20 and 9 or white 16 pin plug, pins 1 and 5. These wires short when the switch is pressed. “
For that should I take a - accessory output from viper and use 2 diodes to send a - signal to them both? Or use a relay to short them? The factory fob or switch in door need long pressed to open gate.
Sounds like a simple install. You all are awesome and it’s greatly appreciated
Thank you.2015 Honda Pilot EX L, Viper 4606 Install -- posted image.
Eric M
Posted: March 27, 2019 at 8:40 PM / IP Logged Link to Post Post Reply Quote kreg357
I think before I got carried away, I would see what the Viper Trunk Release button and the ADS AL-CA do.
While the Pilot in the Pictorial did not have a power liftgate, the R/S system did pop the rear glass
panel when the R/S Trunk Release button was pressed. Going by the DL HA3 install guide, it does call
its' output signal Trunk/Hatch Release and Trunk/Liftgate so it might just handle the power liftgate.
If it does not, you can always add that feature. I would use a mini-relay controlled by either the
Trunk Release output or an AUX output. You would need to verify the proper wires mentioned in that
info you listed. No diodes would be necessary. Relay wiring below :
Relay Pin 86 to +12 Constant
Relay Pin 85 to Viper Trunk Release or AUX output
Relay Pin 30 to either wire, say Brown
Relay Pin 87 to either wire, say Purple
The relay would do the same thing the Pilots Trunk Release switch does. Also check to see if the
power liftgate actuates the alarm. You might have to do a Disarm prior to opening the rear hatch.
The bypass module should do this for you if it opens the liftgate.
mcgrathe
Member - Posts: 15
Posted: March 27, 2019 at 9:13 PM / IP Logged Link to Post Post Reply Quote mcgrathe
Ok. Makes sense. Sounds easy enough. Yeah this Pilot won’t open gate until unlocki/disarm from factory remote. I’ll make sure to disarm if I have to relay it which would definitely override that unlock only function if a relay forces the signal.
If I didn’t already have the viper I’d of just went all idatalink with blade. I also have an Automate 5304a which is pretty much a Viper 5706v far superior to the 4606 but I don’t want the alarm function in this install. I’ll probably program my 2 way remotes to this viper after everything gets working. It’s a LCD remote.
Anyhow thanks again for help. I’ll be sure to report on what works with this AL CA.
Eric M
mcgrathe
Member - Posts: 15
Posted: April 17, 2019 at 10:07 AM / IP Logged Link to Post Post Reply Quote mcgrathe
Ok. So i just noticed on page 3 of the idatalink DBI-AL instructions it requires a Ground When Running connection from the Viper.
Would this be the dark blue wire (pin 5) on 24 pin connector of viper? And where do i connect this wire?
2015 Honda Pilot EX L, Viper 4606 Install -- posted image. 2015 Honda Pilot EX L, Viper 4606 Install -- posted image.
Eric M
Posted: April 17, 2019 at 4:31 PM / IP Logged Link to Post Post Reply Quote kreg357
I'll give that a "conditional yes".
Two things to mention :
1. If you are going D2D between the Viper and the ADS AL-CA, GWR to (-) Status Output is handled by the D2D harness. There is no reason to run a hardwire connection. If you are going W2W, then, yes, you must make the physical hardwire connection.
2. That note about the ADS AL-CA GWR input has to do with signal timing and not the connection type. It should not be an issue with a current model Viper system as they have the correct Status output timing.
mcgrathe
Member - Posts: 15
Posted: April 18, 2019 at 6:10 PM / IP Logged Link to Post Post Reply Quote mcgrathe
So I grounded the black white wire pin 13 and everything works.
It remote cranks and starts. Stays running. The odd issue though is the ADS-AL CA is constantly buzzing/clicking like a relay or something inside it is going off.
This is while it’s running only. This can’t be norm I’d guess. Any thoughts?
Eric M
