Running 2 amps with 1 RCA out from Radio?
carguy411
Silver - Posts: 683
Posted: January 27, 2004 at 5:57 PM / IP Logged
im running 2 amps a mono amp for 2 subs and a 4channel for the interior speakers. now what is the best way to hook this up for iptimum sound. i can run into the mono amp from the alpine cva 1003 and come out of the amp into the 4 channel but then how do i hook up the other 2 channels on the 4CH amp. i know it seem confusing but im not sure if i just use "y" adapters to do it or get some kind of output sp;litter or something
please let me know thanks
DYohn
Platinum - Posts: 10,741
Posted: January 27, 2004 at 6:10 PM / IP Logged
I'm not usre I understand your setup, but to answer your question in general, yes, you can use a Y-cable and split a single RCA output to send to two amps.
customsuburb
Gold - Posts: 1,813
Posted: January 27, 2004 at 6:33 PM / IP Logged
If you give me both your amps brand and modle I can answer your question better.
mobiletoys2002
Gold - Posts: 1,050
Posted: January 27, 2004 at 6:36 PM / IP Logged
you will have no fading capabilities or sub control!
carguy411
Silver - Posts: 683
Posted: January 27, 2004 at 6:45 PM / IP Logged
im using the jl audio 1000/1 sun mono amp and the 300/4 jl amp
and a Alpine CVA1003 Headunit
please let me know the best way to do this with out loosing quality
thanks
forbidden
Platinum - Posts: 5,354
How many pre outs does the cva 1003 have and what are they labelled as?
Post up the amp brand and model# as well please.
customsuburb
Gold - Posts: 1,813
Posted: January 27, 2004 at 6:48 PM / IP Logged
If your reciever only has one set of preamp outputs then I would definitely consider getting a crossover. A good one will let you route one or two pairs of rca preamp inputs into it and then have 1 output of for the front speaker ,one for the back speakers ,and one for your sub amp. It should also have crossovers for each channel (hints the name) and level controls. This will give you far better control over your system. If you have enough money I would go with a zapco one otherwise just go with something from kicker probly. heres a link to a zapco one with a built in eq also. you might not need all the features of it but the zapco has it all.
carguy411
Silver - Posts: 683
Posted: January 27, 2004 at 6:58 PM / IP Logged
it only has a rear/sub output form the alpine
i did post the brand names and model # of the amps
"im using the jl audio 1000/1 sun mono amp and the 300/4 jl amp"
Clean Install
Silver - Posts: 446
Posted: January 27, 2004 at 7:16 PM / IP Logged
thats the only problem I see as well...
Doug
If we learn from each success and
each failure, then we can improve ourselves
forbidden
Posted: January 27, 2004 at 7:23 PM / IP Logged
Missed your post, must have been put up as I was typing. This is a case where I would be looking into a eq / line driver or outboard crossover / line driver, both with remote sub level control. The line driver will make the amps job easier to produce good clean power, the remote sub level speaks for itself, the eq is also going to be not just a tweak piece but also a master volume control. Have a look at www.audiocontrol.com for some really good ideas on expanding your system using dedicated to the task processors.
Page of 3
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
