’95 Ford Mustang alarm/remote start
Synned
Member - Posts: 11
Posted: August 06, 2005 at 12:41 PM / IP Logged
Okay I have done some research on this... I am installing an aftermarket alarm/remote starter in my 95 mustang with factory keyless entry. I know it uses the 3 wire negative pulse for the doors. Do I leave the factory keyless entry module intact and just tap into the wires in the kick panels, or do I remove the factory harness and do something else. Also, why are there 3 ignition wires and which one is hot when the car is on etc? I need to wire 2 different ones I don't know which or what to do. Thanks guys, I really can't afford to take this to a shop lol.
mo12v
Posted: August 06, 2005 at 3:03 PM / IP Logged
Yes......tap into Factory Lock / Unlock wires
NO.......Do NOT remove Factory RKE
Not knowing the Brand & Model RS/Alarm U R installing, U may need a couple of SPDT RELAYS for your Ignition hook-up also
Ignition Switch Layout: Ignition #1- TAN/WHT.............Powers Ignition Coil (Primary Ignition)
Ignition #2- GRY/YEL.............Powers Blower Motor(2) *
Ignition #3- GRY/YEL.............Powers Trans. Control *
Ignition #4- BLK/L GRN...........Powers Heat-A/C Controls *
2 Of These 3 GRY/YEL Wires Are One Circuit
MO
Synned
Member - Posts: 11
Posted: August 06, 2005 at 3:23 PM / IP Logged
I am insatlling a crime stopper CS-2016FM Deluxe 2-WAY Fm Paging Alarm and Remote Start Combo System.
I didn't think I needed a relay for remote starting, all I did was splice into the starter wire, WHITE/ pink, and ignition BLACK/ grn. I didn't have to use relays. i THINK. Do i need to touch the grry/yel wires? I didn't.
Synned
Member - Posts: 11
Posted: August 06, 2005 at 4:07 PM / IP Logged
mo12v
Posted: August 06, 2005 at 9:52 PM / IP Logged
To prevent "Check Engine" Light or ERROR codes, U need to Power up ALL Ignition Wires.  If U want the AC / Heater to work that also needs to be powered up.
I believe U only have 2 Ignition ( Ign 1 & 2 ) wires coming from your CS-2016FM .
U will need 1 or 2 Relays, depending on which other wires U need powered up
MO
Synned
Member - Posts: 11
Posted: August 07, 2005 at 12:59 PM / IP Logged
Thanks mo12v. I can't get the AC blowing. I guess I need a relay. Right now I am only hooked up to one of the gry / YELLOW wires is that alright?
Synned
Member - Posts: 11
Posted: August 07, 2005 at 1:05 PM / IP Logged
If I need a relay what type of relay do I get? I have no idea.
Synned
Member - Posts: 11
Posted: August 07, 2005 at 1:53 PM / IP Logged
So I bought a relay, I have no idea what to do! Isn't a relay like a switch?
Synned
Member - Posts: 11
Posted: August 07, 2005 at 2:50 PM / IP Logged
Okay, sorry for all the posts but I need to get this working. Everything works except the A/C. I think its because I don't have a valid tach input. Can anyone give suggestions/verify this?
Mharvey
Copper - Posts: 76
Posted: August 07, 2005 at 3:45 PM / IP Logged
Friday, December 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
