1999 Durango power locks
Mitten Diver
Member - Posts: 13
Posted: October 03, 2006 at 6:54 PM / IP Logged
Shaggy it is actually in the white lower plug, located next to the unlock wire. There are only two orange wires with strip, but there could be a brown wire with orange strip. I gues I could try that.
John
shaggy12volt
Copper - Posts: 164
Posted: October 03, 2006 at 7:23 PM / IP Logged
just test them it should be there but doodie happins what is the date code on your durango just wanted to make sure you dont have an early 2000
The Shagmaster
1999 Chevy Suburban 15" lift sittn on 22's sets 7'5"
1992 Chevy Astro Van all Bagged out Dubbed THE SUICIDER
Installing for over 18 years Looking for empolyment NOW send PM for resum
Mitten Diver
Member - Posts: 13
Posted: October 03, 2006 at 7:27 PM / IP Logged
manufacured 12-98.
John
shaggy12volt
Copper - Posts: 164
Posted: October 03, 2006 at 7:30 PM / IP Logged
yep its a 99 did you look at the wires coming off the switch itself what wires on the 451m did you hook to what? just trying to norrow things down for ya
The Shagmaster
Mitten Diver
Member - Posts: 13
Posted: October 03, 2006 at 7:45 PM / IP Logged
I have the blue with black of the 451 connected to the pink with purple and I had the green with black from the 451  connected to the orange with purple of the harness. I have heard that tis system may be a five way system sould I be using all of the wires on the 451 to interrupt the wiring?
John
shaggy12volt
Copper - Posts: 164
Posted: October 03, 2006 at 8:46 PM / IP Logged
i have not seen a durango a five wire but you can test the wires and see if it is
The Shagmaster
