05 pacifica wont start with key
ls1nova
Member - Posts: 15
Posted: January 27, 2007 at 1:06 PM / IP Logged
I just got the entire remote start done and I went to program the tach and now it won't start with the key.  The security light comes on solid and it won't crank at all.  Help please.
I did have an issue when I was programing the CHU.2  While I was doing it the battery went all but dead (just my luck)  I couldn't have erased the program from the 2 factory remotes could I?
Thanks a ton,
Frank
Platinum - Posts: 12,488
Posted: January 27, 2007 at 1:50 PM / IP Logged
Disconnect the PKU-CH2 and make sure that the battery is fully charged. Try place the key into the cylinder but do not turn it over. Take note of the LED in the dash just to make sure that the LED goes out after 3 seconds after ignition is turned to the ON position.
ls1nova
Member - Posts: 15
Posted: January 27, 2007 at 2:06 PM / IP Logged
it does go out.
I disconected the battery and tried it.  The horn honked 3 times and it still won't start.
Posted: January 27, 2007 at 2:08 PM / IP Logged
Disconnect the PKU-CH2 and make sure that the battery is fully charged.Try to start without the bypass module in the loop.
ls1nova
Member - Posts: 15
Posted: January 27, 2007 at 2:09 PM / IP Logged
I actually have everything unhooked from the ign. wires right now and it still won't do anything.  It must went into some type of tamper mode or something.  Is there any way to get it out of that mode?
Thanks,
Frank
ls1nova
Member - Posts: 15
Posted: January 27, 2007 at 2:15 PM / IP Logged
The module is unhooked also.  Still no go.
au5599
Copper - Posts: 95
Posted: January 27, 2007 at 7:24 PM / IP Logged
disconnect all wires going to any starter wires then try it again. did you happen to check all fuses to make sure you didnt blow one?
Street Dreams Car Club
93 GRAND CARAVAN SE / Astro
Team New York SS3-4 06 & SM3-4 07 DB Drag World Finals
2003 Chevy Suburban LT / 98 GTP
Posted: January 28, 2007 at 12:57 AM / IP Logged
Have you tried both keys ?
ls1nova
Member - Posts: 15
Posted: January 28, 2007 at 7:29 AM / IP Logged
Yes.  Neither one will do anything.  Is there any way to reset the Chrysler's like the GM vehicles?  Like leaving the key on for so long or something along those lines.
Thanks,
Frank
splaudio
Copper - Posts: 237
Posted: January 28, 2007 at 7:51 AM / IP Logged
did u check ur fuses like said above? that a dmm and check to see if ur ignition wire has power when the key is turned to on...
