2000 maxima remote start
ikhmaifosho
Member - Posts: 18
Posted: November 14, 2007 at 10:21 AM / IP Logged
also do i have to disarm the factory security module?
KarTuneMan
Platinum - Posts: 7,056
Posted: November 14, 2007 at 10:30 AM / IP Logged
as for the 3rd ignition i treated like a second start and wired it like so with the relay
30 = BLACK/ Blue Start side
87 = BLACK/ Blue Key Side
85 = Pink (-) 200ma 3rd ignitons output on the relay off the relay satellite wiring small gauge
86 = wired to acc then 12v nothing
If I am not mistaken....you cannot trigger a second starter, with an ign. input.
And you most certainly don't need to CUT the wire and seperate it out on the the pins of the relay.  (like you did, starter side, and key side)
put the wire back together. Configure a relay to "throw" 12volts. to be triggered by a negative output that syas "second start" it's got to be there.... it's a viper.
Relay as such 12v fused to 87, and 86. negative starter out from the brain to 85. 30 attach to your second start......
The is NO 3rd. ign.
There is NO 2nd accs. needed (there may be a wire that tersts as nd accs. but it's not needed)
Batt.=Dk.green
Ign= blk/red (medium sized)
start1=blk/red (big one)
start2=blk/blue
accs=red
dcman41
Copper - Posts: 211
Posted: November 14, 2007 at 10:53 AM / IP Logged
Do the second starter like the diagram i posted on the first page. Also the factory security will arm with lock, and disarm with unlock. Make sure you set double pulse unlock as well.
ikhmaifosho
Member - Posts: 18
Posted: November 14, 2007 at 9:38 PM / IP Logged
thanks guys great info, can't wait to finish it up this weekend, also for the power doorlocks not really sure about the double pulse, i found and some wires on the factory security module which tested 12v when pressed lock/unlock, tapped on to them but didn't respond when i lock/unlock on the transmitter? also i dont think this was covered but do i ahve to disarm the factory alarm, if so which wire, thanks for all your support.
dcman41
Copper - Posts: 211
Posted: November 14, 2007 at 10:15 PM / IP Logged
NO, the factory alarm arms on lock, and disarms with unlock on the remote.
Saturday, April 27, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
