98 chevy led tailights
larkster
Copper - Posts: 98
Posted: November 21, 2005 at 8:31 PM / IP Logged
hey i installed a roll pan with led lights for the taillight and brake signal lights.  I got everything wired up and works fine.  except the leds dont have resistance like the bulb so the flasher flashes really fast.  I know you can get low resistance flashers but not for this truck. only  2 or 3 prong flashers.  the one in this truck is a 4 prong my question is can i modify the flasher in the vehicle to work. or is ther another solution available?
fingaz22
Silver - Posts: 410
Posted: November 21, 2005 at 8:54 PM / IP Logged
i dont know if they make a solution for this . but what i would do is get a resistor to get the resistance higher to get a slower flash. you will need to figure out the total resistance you have now from the leds and then adjust accordindly. lol
JUST ONE MORE AMP!!!
hu,alpine cva 1005/dva 5205
sound processor,symmetry(first one).
sub amp,power 1000 the terminator.(1992).
subs,spl comp dual 1 ohms.
punch 150hd on a 10" ev.
alotofhighs
ff-mike
Copper - Posts: 199
Posted: November 23, 2005 at 1:59 PM / IP Logged
He needs to reduce the resistance, not increase it. The original bulbs have a resistance of ~1/2 ohm, and the LEDs are probably around 25 ohms effectively for a 15 LED array.
boyzWidToys
Member - Posts: 26
Posted: November 26, 2005 at 8:18 PM / IP Logged
ff is wrong.
you do have to raise the Resistance.
i would lean towards retrofitting the Heavy Duty Blinker to your truck.  The heavy duty blinker will blink at a constant rate, regardless of the Resistance.
