python 1400xp, matrix ecm recall
buddyle2002
Member - Posts: 39
Posted: August 01, 2011 at 12:16 PM / IP Logged
I installed the python 1400XP on my 2006 toyota matrix last summer.  It work great.  However after the toyota had the Matrix ECM recall, I had my car replaced with the NEW ECM, now the remote start is NOT working any more.  Verified all wired connection are good.  remote lock and unlock is fine.  When i start the car, it just crank a few time and try to start, but it won't.  At this time I don't know what to do at this time.....if anyone have any ideas, please HELP!!!
Here are thing that i have tried:
Removed the battery completely.
Unplug the remote start unit and verified all the wire connection.
Ween
Platinum - Posts: 1,368
Posted: August 01, 2011 at 10:00 PM / IP Logged
hi,
i'm thinking the ecm stores the transponder key codes. new ecm, keys reprogrammed but the bypass module is not.
mrk
dasbogie
Silver - Posts: 514
Posted: August 02, 2011 at 2:37 AM / IP Logged
did you try reprogramming tach?
Advanced
Mike M2
Platinum - Posts: 2,652
Posted: August 02, 2011 at 6:30 AM / IP Logged
I think Ween is right. Try setting the key in the ignition switch without turning it and try to remote start it. If it goes it isn't seeing the key code anymore....
Mike M2
Tech Manager
CS Dealer Services
buddyle2002
Member - Posts: 39
Posted: August 03, 2011 at 10:36 AM / IP Logged
I already tried that and it won't start.  it just trying to start and cranking.  are there way to reset the by pass module? (XK05 TRANSPONDER IMMOBILIZER BYPASS).
