Alarm for a 2012 Toyota 4Runner SR5
lowcel
Member - Posts: 8
Posted: March 11, 2016 at 7:10 PM / IP Logged Link to Post Post Reply Quote lowcel
Hello everyone, I could use some help. I want to install a somewhat basic alarm in my 4Runner. I am installing it to get extra points in the MECA installation class. My requirements are two sirens, battery backup, door sensors, glass breakage sensor, and keyless entry. I'm looking at the Viper 3305v alarm. I am open to other alarms as well if they will do the same thing and are easier to install.
My vehicle is a 2012 Toyota 4Runner SR5 that came with GPS and satallite radio if that matters for installation. Could anyone give me a wiring diagram for the wires that I will need? I'm hoping this is something I can handle on my own.
Here is a picture just because...
Alarm for a 2012 Toyota 4Runner SR5 -- posted image.
geepherder
Platinum - Posts: 3,668
Posted: March 12, 2016 at 8:31 PM / IP Logged Link to Post Post Reply Quote geepherder
http://readyremote.com/main.asp?action=select&yr=26306&product=Security&make=Toyota&model=4Runner
lowcel
Member - Posts: 8
Posted: March 12, 2016 at 8:36 PM / IP Logged Link to Post Post Reply Quote lowcel
Thank you. For a basic alarm like I mentioned in my original post approximately how many of those wires will I need to tap into?
manahawkinrob
Copper - Posts: 58
Posted: March 13, 2016 at 7:18 AM / IP Logged Link to Post Post Reply Quote manahawkinrob
You keep mentioning a a basic alarm but than you say you want 2 sirens, battery backup and GBS. That is not really basic. You will probably have to add some relays to power 2 sirens and will need to configure some features for the GBS.
Your best bet is to sit down and read the installation instructions and determine what features and connections you will need. Than you can ask specific questions about how to wire the relays or where / how to connect something etc.
Asking general questions or asking someone to map out your entire install won't get a lot of responses.
Hope that helps.
lowcel
Member - Posts: 8
Posted: March 13, 2016 at 7:26 AM / IP Logged Link to Post Post Reply Quote lowcel
Hope that helps.
I hate it when someone posts a reply that I don't want to hear that makes sense. I guess in my mind not doing remote start, windows, hatch pop, and things like that make it basic. With that said I completely understand what you are saying and I appreciate you taking the time to explain it to me.
lowcel
Member - Posts: 8
Posted: March 13, 2016 at 10:33 PM / IP Logged Link to Post Post Reply Quote lowcel
Could you tell me the difference in the power lock wires and the lock motor wires?
geepherder
Posted: March 14, 2016 at 7:34 PM / IP Logged Link to Post Post Reply Quote geepherder
Power lock wires are low current trigger wires that control the door locks- they might trigger relays directly, or go to the BCM. The door motor wires are the wires that physically run to the door lock actuators themselves.
ak609
Member - Posts: 47
Posted: March 14, 2016 at 7:37 PM / IP Logged Link to Post Post Reply Quote ak609
power wires is just a negative wire that activates the relay for the lock and unlock motors where as the motor wire activates the motor direct. On that car though i used use your factory arm and factory disarm wires instead always use them for auto starts instead of the lock and unlock wire.
lowcel
Member - Posts: 8
Posted: March 14, 2016 at 7:40 PM / IP Logged Link to Post Post Reply Quote lowcel
So for the keyless entry do I use the Power Lock / Power Unlock or the Lock Motor / Unlock Motor wires?
ak609
Member - Posts: 47
Posted: March 14, 2016 at 8:01 PM / IP Logged Link to Post Post Reply Quote ak609
Use the power lock and unlock wires or youll be going to all the doors to activate the locks. if you dont use factory arm and disarm for keyless entry make sure to at least hook up the disarm wire.
Friday, October 31, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
