97 plymouth voyager remote start
letech31
Member - Posts: 11
Posted: November 16, 2003 at 4:54 AM / IP Logged
hi
i want a diagram wires for plymouth voyager 1997 auto,i have autostart  AS-1515 SH.any help plz
draasch
Gold - Posts: 2,172
Posted: November 16, 2003 at 9:38 AM / IP Logged
Make:   Plymouth
Model: Voyager
Year:    1997
This Database Was Last Updated On:    6/9/03
Index #: 6424
Alarm
Constant 12 volts PINK/BLACK, RED & PINK IGNITION SWITCH HARNESS
Ignition 12 volts D BLUE IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light BROWN / L GREEN (-) GRAY 36 PIN CONNECTOR AT FUSE BLOCK *
Trunk Pin Switch TAN/BLACK 40 PIN NATURAL CONN. AT FUSE BLOCK
Parking Lamp BLACK / YELLOW (+) GRAY 36 PIN CONNECTOR AT FUSE BLOCK
Power Lock WHITE/ D GREEN BLACK 14 PIN CONNECTOR #217
Power Unlock SINGLE WIRE SYSTEM IN DRIVER KICK PANEL **
* BROWN / L GREEN (-) Wire Can Also Be Found At Headlight Switch. ** Single Wire Door Lock System, WHITE/ D GREEN Wire Requires Chassis Ground Thru A 1.5K Ohm Resistor To Lock And Chassis Ground Thru A 249 Ohm Resistor To Unlock. #217- See Single Wire Resistor Door Lock Diagram.
Remote Start
Tach Signal GRAY & D BLUE/TAN AT POWERTRAIN CONTROL MODULE (2.4L) *
Ignition #2 BLACK/ ORANGE IGNITION SW. HARN. (HEAT/AC) #235
Ignition #3 D GREEN/ RED IGNITION SW.HARN.(TRANS CONTROL MOD.)
Accessory BLACK/ WHITE IGNITION SWITCH HARNESS
Neutral Safety BLACK/ WHITE (-) AT POWERTRAIN CONTROL MODULE
Brake Light WHITE/ TAN (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light VIOLET/BLACK (+) BLK 10 PIN CONN. ON DR. FRONT OF ENG.
Rear Window Defrost N/A TIMER BUILT INTO SWITCH
* Each Wire Listed Above Is A 2 Cylinder Signal. 3.0L Tach Wire Is GRAY/RED At Powertrain Control Module (PCM). 3.3L & 3.8L Tach Wire Is GRAY/RED, D BLUE/TAN And RED / YELLOW At PCM (Each Wire Is A 2 Cylinder Signal). PCM On All Models Located On Driver Fenderwell. #235- See Powering Additional Ignitions Diagram.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
letech31
Member - Posts: 11
Posted: November 17, 2003 at 11:15 AM / IP Logged
hi
i need help,plz for diagram and shema for autostart as1515 sh,i have the manuel,but there is no shema.thks
Digger67
Member - Posts: 23
Posted: November 17, 2003 at 12:09 PM / IP Logged
Looking for wiring diagrams for autostart try here with your AS Ser# and make of car will get you them. http://206.47.191.115/autostart.nsf
letech31
Member - Posts: 11
Posted: November 17, 2003 at 12:31 PM / IP Logged
this is description for as1515 sh,but i need a diagram for this item,what means any wires plz
derek123
Copper - Posts: 163
letech31
Member - Posts: 11
Posted: November 21, 2003 at 3:26 PM / IP Logged
hi
i have a starter car,model:AS1515-SH,i installed it ,but its started for 4 seconds and stopped,plz any help
profuse007
Gold - Posts: 2,015
Posted: November 21, 2003 at 3:35 PM / IP Logged
model/year of the car?
Houston,TX
letech31
Member - Posts: 11
Posted: November 21, 2003 at 3:36 PM / IP Logged
i have plymouth voyager 1997
profuse007
Gold - Posts: 2,015
Posted: November 21, 2003 at 4:22 PM / IP Logged
| SECOND IGNITION|BLACK/ orange        |+ |ignition harness            |
dont forget the second igntion, see if it helps
i dont think its the tach sense, it stay for 4 sec and thats a long time. if you need to re-learn, do so.
good luck
Houston,TX
Wednesday, November 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
